Featured Ford teases electric F-150 towing 1 million pounds
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by Ashlem, Jul 23, 2019.
  1. Prodigyplace
    12,532
    11,750
    Central Virginia
    Somebody with a hearing problem hits the button to stop the engine but actually starts it. :mad:
    Would an accidental double-tap keep it on?
  2. PA Prius
    PA Prius Active Member
    762
    251
    SE Pennsylvania
    I was referring to "engine." It doesn't even have an engine, it has a motor.
    3PriusMike and Prodigyplace like this.
  3. austingreen
    austingreen Senior Member
    13,671
    4,209
    Austin, TX, USA
    poorly. They mention they are going 4.5 mph (2 m/s for easier calculation), 700 lbs of frictional force is about 3100 newtons, so they would need to apply 3100x2 = 6200 watts or 6.2 kw to just overcome rolling friction at that speed. It took a lot more power to get going, but as you say you could gear it up enough and accelerate slow enough with a skinny girl with the right bicycle contraption.
    I guesstimate 11 kw using slightly different assumptions. A football team on bicycles geared right could probably do it. I believe the strongest man could do something like 2.5 kw for 10 seconds, but we are talking more power to start.
    Its a pretty cool demo though, the key here is the trick is railroad tracks to reduce friction, and not attaching a rigid trailer that would rip most trucks appart.
    A plug-in truck should be able to tow better and more controlled. The thing ford is demonstrating is that plug-ins can tow, which a lot of people would think a plug-in would be worse at towing because normal hybrids are. I expect the hybrid f150 will have a better tow envelope than its regular gasoline counterpart, but won't get the mileage boost, because it will be tuned to this. With a bev you don't need that 10 speed transmission with a very low gear (in ford its 7.44 x bigger ratio than its 10th gear overdrive for highway cruising).
    I still think because of the high energy demands of off roading and towing a phev pick up is a better choice. Tow that train and using my figures even going a constant 4.5 mph on level ground its going to use up 80 kwh of battery in just 33 miles.
    Its a prototype that won't be out until at least 2022. I'm sure they just used a standard f150s interior. Maybe it should say on/off.
    #43 austingreen, Jul 26, 2019
    fuzzy1 likes this.
  4. hill
    8,794
    start/stop .... that's how pre-bankrupt GM justified calling their Malibu a hybrid. Fans didn't bite.
    2008 Chevrolet Malibu Hybrid
    then they slapped the 'hybrid' logo on the side of the car -
    I'm sure Ford learned from GM's Shenanigans back over a decade ago. Wouldn't they?
  5. cnc97
    cnc97 Senior Member
    1,422
    1,535
    38
    Evansville, IN
    It’s pronounced mo-TAUR. LoL Just teasing.
    Trollbait likes this.
  6. fuzzy1
    10,407
    Semantics.
    From NASA's "DICTIONARY OF TECHNICAL TERMS FOR AEROSPACE USE"
    "motor
    See engine."
    engine
    A machine or apparatus that converts energy, especially heat energy, into work. Also called motor."
    The heat energy part is not universal, numerous other sources don''t have it as a requirement.
    From Merriam-Webster dictionary:
  7. PA Prius
    762
    251
    SE Pennsylvania
    Probably right, semantics, but I'd still have a hard time saying my Bolt has an electric engine.
  8. Trollbait
    12,505
    It's a prototype using off the shelf parts available now.
    The Explorer hybrid is rated 5000 pounds for towing, but the Police Interceptor is only 24mpg combined. I don't see the Explorer's official numbers changing much from that.
  9. bwilson4web
    16,190
    In recognition of the Family Formicidae:
  10. bisco
    51,841
    yeah, fords not getting a lot of love lately, and their constant future prognostications aren't helping.
    still the most popular truck in the world though, fwiw
  11. Prodigyplace
    12,532
    11,750
    Central Virginia
    I get “video unavailable “
  12. bwilson4web
    16,190
  13. austingreen
    13,671
    4,209
    Austin, TX, USA
    That will be disappointing if the f series hybrid is that low. 5000 is fine for the explorer and is probably limited by that atkinson normally aspirated 6. I would expect a f-series pick up hybrid to have a turbo engine for torque - either 4 or 6, which that hybrid system can accommodate fine (lincohn aviator uses a turbo 6). I think an atkinson 6 is a fine choice if the suv or truck had more battery power like the aviator phev, but the explorer only has 1.5 kwh - probably only 70% usable so figure 1 kwh usable that will get used up fast if towing or going off road.
  14. Leadfoot J. McCoalroller
    8,069
    7,552
    Pennsylvania
    2018 Prius c
    Truck loading (including towed loads) is very much dictated by braking capability, both in terms of continuous availability through the powertrain and the friction brakes for stopping. An F-150 is going to be rated similar to the Explorer, though the truck’s longer wheelbase will make it the better tow vehicle, pound-for-pound.
    austingreen likes this.
