Foreign Object on Wheel Speed Sensor Questions
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by rjparker, Apr 18, 2014.
  1. Air_Boss
    Air_Boss Senior Member
    4,248
    1,195
    New Yawk
    Have you checked the connector and harness wiring?
  2. Melthias
    Melthias Member
    110
    37
    Southern Maine
    I just checked the connection that goes from the car to the sensor. Everything seemed fine, no corrosion or bent pins.
    Air_Boss likes this.
  3. Air_Boss
    4,248
    1,195
    New Yawk
    Wire continuity when flexed? The wire may flex at speed (undertray wind, vibration) opening up a break in the conductor.
  4. Melthias
    Melthias Member
    110
    37
    Southern Maine
    Hmm, interesting suggestion. I doubt that will be it, but if so I would want to know. I will try that next I suppose.
  5. Air_Boss
    4,248
    1,195
    New Yawk
    Intermittents are the worst to trace...
