Forgot to turn Prius off
Discussion in 'Gen 2 Prius Main Forum' started by Nikim, Mar 5, 2018.
  1. Nikim
    Nikim New Member
    Wi
    So last night my husband forgot to turn off his Prius. Face palm. First time this has happened. Only discovered it when looking for his keys this morning - it’s a 2005. Parked inside our 3 car attached garage. Door was closed. Our Carbon monoxide detector inside the house and near garage did not go off. Everyone seems fine - do I need to worry about any carbon exposure for us and kids? I do not know much about the Prius - it’s my husband’s car. He will now be more careful. Thank you
  2. Aaron Vitolins
    Aaron Vitolins Senior Member
    1,612
    1,144
    Franklin TN
    It's perfectly fine, the prius hardly runs the engine even when sitting on all night, so don't have to worry about carbon monoxide. Also its totally fine for the battery as well. No worries!
  3. Nikim
    Nikim New Member
    Wi
    Thank you, Aaron....of course I was a mess this morning after googling about cars being left running all night and about ready to check us all into the nearest ER. My husband assured me since our house is not really old (1996) it was fine.
  4. Sam Spade
    Sam Spade Senior Member
    2,036
    1,023
    2017 Prius c
    Hmmmmm.......that's not really a good argument. Houses built last week can be CRAP when it comes to good craftsmanship and proper procedures.
    BUT......if nothing was left ON inside the car, like the HVAC system, the gas engine likely didn't run but a few minutes all night long.
    No need to worry.
    Note: There probably WAS an alarm that went off when he opened the door with it still ON. He should test that and pay attention to the bells and whistles in the future. :D
  5. Frankemtp
    Frankemtp Junior Member
    16
    Chicago, IL
    Four Touring
    I lent my Prius 2016 to friend while I was out of the country. He parked it in my detached garage did not turn it off and it ran for 10 days. I had 1/4 tank of gas remaining and all was good. Just amazing!
    Prii93 and Aaron Vitolins like this.
  6. fuzzy1
    10,603
    If you are conscious and clear-headed enough to do online searches and post this query, haven't been vomiting or nauseous, and the family all has normal skin color, then you should be just fine.
  7. Prodigyplace
    12,690
    11,834
    Central Virginia
    Welcome!
    The Prius is really an advanced engineering marvel! There are many knowledgeable here who can assist with knowledge & dealing with "Prius addiction" :D
  8. padroo
    padroo Senior Member
    2,763
    2,252
    Lucy you, newer cars with catalytic converters turn carbon monoxide into carbon dioxide thanks to modern pollution standards and being a Prius it is even better. I'm not saying the system is perfect but if it was an old car you could be dead.
    I found this to explain more.
    How does the catalytic converter reduce the risks of CO poisoning? The typical catalytic converter found on most newer cars and trucks combines oxygen with carbon monoxide to form non-poisonous carbon dioxide (CO2) reducing the high concentrations in the exhaust manifold (typically 30,000 ppm or more) to low concentrations (typically below 1,000 ppm after the catalytic converter). Tailpipe concentrations of carbon monoxide in gasoline engines without catalytic converters are typically from 30,000 to over 100,000 ppm, depending on the condition of the engine.
