Former Dodge family, Prius won't start.
Discussion in 'Newbie Forum' started by Princer, Dec 24, 2017.
  1. Princer
    Princer Junior Member
    25
    44
    Kentucky
    I am a 2010 prius owner and a newbie here. I married into a Dodge family and that's all I've owned for 40+ years. My inlaws finally got out of the car business so I had a choice of brands this time when I totaled my car. A friend gave me, literally gave even paid the taxes, a 2005 prius when I was looking for a car. It was ugly, wrecked outside and in, but I feel in love. I paid it forward & gave it to a friend who needed a car and bought a used 2010 prius lV with 140,000 miles. The 2005 had over 300K and ran great! I've had this car for 6 months and now today won't start. The batteries appear to be fine but I'll start there. The ABS light had been coming for the past 2 weeks when I pressed super firmly on the breaks. I hadn't had a chance to get that checked out yet. It lights up and seems fine but when I press start nothing happens. Any help would be appreciated.
  2. chronon
    chronon Active Member
    601
    105
    here and there aint be in frozen wasteland no mo..
    that's alot of miles ! i still have the 05 but not currently driving it. had an 01 before that and several other toyotas. A simple solution, (to try) if you can, would be to try and reset the car. Do this by unpluging the battery, or disconnecting either the ground or positive from the battery post or if possible from under the hood in the fuse area if it is more convenient, i dont have a 3rd gen prius so am not familiar with the bat arrangement in it. Another thing, would be to get a code scanner on it, if u dont have one, u can borrow one perhaps from advance auto or esp. autozone or peep boys, they do this regularaly by you paying for it and then bringing it back , and is an accepted policy, they would scan for free if u could get the car to their parking lot. DONT got to the STEALERship !!!!
    #2 chronon, Dec 24, 2017
    RCO and Princer like this.
  3. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,481
    Bay Area, California
    2019 Prius Prime
    What was the voltage on the 12v battery?
    Did you slam on the brakes hard or spin the wheels to cause the ABS light to come on?
    Do you have access to Techstream or a way to read the codes?
    If the car won’t “ready” there is an issue with the 12v.
    All of this can be related to a low 12 volt battery though;).
    Keep us posted (y).
    RCO, scona, Princer and 2 others like this.
  4. chronon
    601
    105
    absolutely, if the 12v bat is low, then the computer will flake out--- with that kind of mileage, if it is the original battery, for sure it is time to replace , that is 7 years; 5 years is all u can expect out of the stock 2nd gen bat. If you can get a voltmeter, aka 'multimeter', ($5 item or less at harbor freight), and test the voltage on the 12v battery, to see what it is at then you would know if you need to charge it. Also the date code of the battery may be on the battery top to let you know if it is original. If you havent driven th car in many days/ left the door ajar, this will also drain the battery down.
    RCO, jerrymildred and Raytheeagle like this.
  5. fuzzy1
    10,149
    Just to avoid possible confusion, the car has a 'hill start assist' feature. This is activated by pressing the brakes super firmly, when stopped. A buzzer should beep just once, and the traction control light (car with squiggly tracks) should light up. If this is what you see and hear, it is normal, and helps prevent rollback when facing uphill. It should go away within a couple seconds after releasing the brake.
    But if the light you see actually has the 'ABS' letters, while the car is not moving, then you are experiencing something else that requires service.
    RRxing, RCO, scona and 2 others like this.
  6. Princer
    25
    44
    Kentucky
  7. Princer
    25
    44
    Kentucky
    Oops sorry about that other post, my finger slipped. The ABS light came on when I was sitting at McDonald's drive-through. I pushed extra hard on the brake when I turned around to reach around in the back seat, does that make sense? I was using the brake to push off and reach back. This made the ABS light come on. When I sit in parked at a red light if I lightly press the brake it doesn't come on but if I push it to the floor real hard, sitting still, it comes on. I don't think this has anything to do with the car not starting but I don't really know.
    RCO likes this.
  8. Raytheeagle
    11,251
    15,481
    2019 Prius Prime
    Sounds like the hill start assist light;).
    As for the no start, check the 12v with a multimeter and let us know the result.
    Keep us posted (y).
    scona, fuzzy1 and Princer like this.
  9. fuzzy1
    10,149
    The specific light doesn't match what my 2012 manual says, otherwise that does sound very much like the Hill Start Assist. The 2010 certainly has this feature too, but I no longer have that manual of that previous car to check. As Ray already mentioned, a normal feature not related to the starting problem.
    When I'm reaching back, I put that car in Park first. That is from a lesson derived from dad almost crushing my leg with a farm tractor when his foot slipped off a pedal while he was doing something else at the same time I was hitching something up to the drawbar.
    Here is the illustration from my Prius manual. There is more written on that page.
    #9 fuzzy1, Dec 24, 2017
    chronon, Princer and Raytheeagle like this.
  10. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    You're going to need to define "won't start". In a Prius, you have close to zero control over the actual starting of the engine. When you press the brake pedal and push the power button, the car READY's. You should immediately hear a bunch of clicking coming from the back which is the high voltage relays connecting the high voltage pack to the car. After the clicking some whirring and the dash should illuminate "READY".
    In your case is the car not going to READY? Is it going to READY and then throwing codes causing the master triangle to illuminate? Basically anything before the car is READY is powered off of the 12v battery. These are lawn mower size batteries. Coming from big 'murican cars like a dodge, it will be an adjustment if you are used to sitting in your car listening to the radio for hours or things like that that just don't exist outside of the states. Meaning it is very easy to kill a 12v battery in the Prius if you don't treat it properly. I know KY is going through some cold now, and a marginally weak battery on a temperate day is a dead battery on a cold day.
    But if the car READY's just fine, you can almost take the 12v out of the equation.
    And your light on the dash with the hard pedal is the hill assist for sure. That's what it is meant to do. Also not a great idea to do that. Put it in Park if you are going to be reaching around the back. If your foot slips off the pedal, and you're leaning into the back seat, that's an excellent scenario for the car to rear end something or someone. Don't do that...
    chronon and Princer like this.
  11. Princer
    25
    44
    Kentucky
    When I get in and push the start button, all the lights come on just as usual but when I push start nothing happens. I don't sit in the car listening to the radio and thanks for the reminder, I shouldn't turn around to the back seat with my foot on the brake. The push button isn't as responsive as it was yesterday. By this I mean I had to push it a few times to turn the car off. I have no idea why it's acting up. Thanks for the help, as you can tell, I am not mechanically inclined and I hate to take it to a deal since I was just there (small town) trying to buy a used car from them. The salesman I was working with even called and tried to talk me out of buying this 2010 from an individual. I bet they'll be thrilled I am in their shop with problems.
  12. Princer
    25
    44
    Kentucky
    No I do not have access to techstream or any other way to test the battery here at home. I will google it and try to get it. I can't take it to auto zone if it won't start. I sure hope it's just the 12v battery. My husband wants to either jump it tomorrow or use our battery charger to try and start it. I hope that won't hurt anything? I am brand new to this prius world. Kinda wishing I still had that beat up old 2005 prius right now. Never gave me a minutes trouble the 4 months I had it, oh well. Too late it's gone. I do appreciate all this info and your comment.
    Aaron Vitolins and Raytheeagle like this.
  13. Princer
    25
    44
    Kentucky
    No I didn't spin and the roads were level and flat when the light came on. Usually at a stop light or drive through. Will try to learn more about techstream, sounds like I need it! All the lights on the dash come on as usual but the start button isn't working. When I push it and then put the car in gear nothing happens. I had a hard time turning it off as well. Took 3 tries of pushing the button to get it turned off. Thanks so much!
  14. Raytheeagle
    11,251
    15,481
    2019 Prius Prime
    Maybe a light was left on draining the 12 volt?
    What kind of battery charger do you have?
    Does your husband have a multimeter?
    Might be worth hooking the charger up for a couple of hours;).
    Good luck and keep us posted (y).
  15. Princer
    25
    44
    Kentucky
    Not sure of the brand, it's an old one from sears. We've used it for years for lawn mowers and sometimes cars. Guess we'll try it. Thank you again!
    chronon and Raytheeagle like this.
  16. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Doesn't make any sense to me. When you get in the car and press the start button, "all the lights come on" but then at the same time "nothing happens"? These contradict eachother.
    When you get in the vehicle, put your foot on the brake pedal and press firmly, then press the start button, what happens...
    That's the classic dead 12v symptom.
    I go to KY all the time (I'll be there next week) and I see how the Prius is usually looked down upon out there. If it doesn't spew black smoke it is not a real car. Only place I have ever been where I see "Friends of Coal" license plates everywhere... ridiculous.
    If you reverse voltage the Prius (like most modern vehicles) you will cause thousands and thousands of dollars of damage. In "the old days" you just smoked the battery, maybe some battery acid to reconfigure your face. Nowadays, fuses blow, FETs blow, ECUs blow, lots of things to replace. So yes you CAN jump start a Prius (or any modern car) but take extreme caution. One single mistake can cost $6K to fix. We've had a few people over the years post about their husbands or brothers or fathers "helping" by jumpstarting and shorting things with the jumper cables, sparking things, and reverse voltage. Don't be the next victim of that, be careful.
    You may also want to educate whoever is doing this if they aren't used to a hybrid, that the 12v battery is basically useless in a Prius. It does not and never will "crank" the engine. The 12v battery only has to switch a few relays and then the high voltage battery takes over. The engine is started by spinning MG2 via the high voltage battery which spins the engine electrically, starts to inject fuel, and then the engine is started. It is nothing like a normal car. There is no "chugga-chugga-chuuuuuga" type sounds when the 12v starts dying. An extremely dead 12v battery will still start the Prius. Usually it goes from working (under extreme duress) to not working. Because it's duty is so light.
  17. Raytheeagle
    11,251
    15,481
    2019 Prius Prime
    A word of caution if trying to jump the car. Avoid this if at all possible (if done incorrectly, you’ll have a bad Christmas).
    In your owners manual it tells you the steps to jump the Prius. Make sure to get the polarity correct as damage to the inverter could result if polarity is crossed.
    Use jumping as a last resort and report back the 12 volt reading when you get a multimeter. You can take the battery out of the car by disconnecting it in the hatch and find a family member or neighbor who might be able to help;).
    Happy holidays(y).
    Princer likes this.
  18. Princer
    25
    44
    Kentucky
    Sorry I am so tired my posts aren't clear or making sense. What I am trying to say is it doesn't act like a battery problem because the dinging noises come on and the lights on the dash come on like they always have in the past. When I push the start button, nothing happens, by that I mean I can't drive the car. It won't start/move. I am in far western Ky near the Tn border. No coal mines here but they are several 100 miles east. I know what you mean about the attitudes. More trucks than cars here. I see a few Prius, not many. I do love mine, even tho it's being a pain right now. TY!!
    RCO and Raytheeagle like this.
  19. Princer
    25
    44
    Kentucky
    Will do and Merry Christmas to you!
    Raytheeagle likes this.
  20. Raytheeagle
    11,251
    15,481
    2019 Prius Prime
    So the interior lights come in but the “ready” light never displays?
    If this is the case, there is some voltage left in the battery, but not enough to power the computers to tell the car everything checks out.
    But by now, the 12 volt has been drained even more, so either charge it up or wait u til after Christmas to get a new one.
    Or maybe Santa will leave one under the tree tomorrow (y).
    Dxta, scona, jerrymildred and 3 others like this.
