Found a different workaround for the instrument cluster
Discussion in 'Gen 2 Prius Technical Discussion' started by Infamous6i9, Mar 3, 2019.
  1. Infamous6i9
    Infamous6i9 Junior Member
    61
    Los Angeles
    For the people who still have that cluster problem i recently found a workaround by accident. Dont know if it was mentioned here before.
    But when my cluster wouldnt turn on when i start the car i would just turn it back off. Then i would turn the headlights on 2 - 3 times till i got the light bulb indicator on in the dash. Then the cluster would work again upon restart.
    Just wanna see if it will help others with the problem.
    SFO likes this.
  2. EpicDad
    EpicDad Junior Member
    I've been having issues. Will try this and see if it works for me too.
    E6910 ?
  3. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    Lol yes that will fix all the dying caps in the combo.
    Seriously, be aware that dying Combo will eventually turn into the car wont shut off. You will have to disconnect the 12 volt battery to kill the car.
    Took mine about a year of intermittently dying to get to the car wont shut off mode. I recommend you buy a new combo board and be ready. Use Matt from Texas Hybrids he's a good member here and rebuilds boards.
    jerrymildred and Skibob like this.
  4. Infamous6i9
    61
    Los Angeles
    Actually the last owner had that problem and she taught me the hold the power button 3 second and double click to turn off. She never knew about the light switch thing. Its a 2004 prius with 210k miles worst comes to worst ill get the cluter repaired for 160
  5. EpicDad
    It took us awhile to figure it out, but ever since I learned I could just hold down the button for long enough, I haven't had an issue with it turning off. 2008 with 140K. Planning on replacing the cluster if we don't trade it in (for a newer Prius, of course)
    E6910 ?
  6. edthefox5
    10,096
    4,837
    Clearwater, Florida
    Yeah that works ok till all of a sudden it doesn’t.
    Skibob likes this.
  7. EpicDad
    Flicking lights thing wouldn't work for me. Oh well.
    E6910 ?
    SFO likes this.
  8. dolj
    dolj Senior Member
    8,631
    4,385
    Wellington, New Zealand
    @Infamous6i9 and @EpicDad, to reiterate what edthefox5 is trying to tell you, this is not a fix but a workaround. It works until it doesn't anymore.
    The fix is to replace the CM (combination meter) with a repaired one from someone like Matt @Texas Hybrid Batteries who offers a good product. It is a good idea to plan to do this before it finally fails.
    Skibob, Raytheeagle and edthefox5 like this.
  9. Infamous6i9
    61
    Los Angeles
    Did u try turning it on slowly and off until u see the headlight indicator.. trick is to do it slow for me
  10. Infamous6i9
    61
    Los Angeles
    Thanks. Well again its a workaround. If worst comes to worst i live quite close to KlaxonPro Hybrid Technology and they charge 160 lifetime warranty.
  11. EpicDad
    Oh yeah for sure. I plan on replacing the combo meter. Just the whole trying to get it on temporarily didn't work for me yesterday. It been going out intermittently for awhile now. Probably started about a year ago, but we didn't have many issues through summer, which is why replacing the meter got out on the back burner. Now that it's winter again, it's happening at least every other day. I'll probably get the combo meter this year.
    E6910 ?
  12. edthefox5
    10,096
    4,837
    Clearwater, Florida
    If that includes installation that’s a good deal. You can see what it takes to install on youtube called
    Prius combo meter
    Infamous6i9 likes this.
  13. Infamous6i9
    61
    Los Angeles
    Hell of a good deal. I found them on this forum from other prius users in Los Angeles
    #13 Infamous6i9, Mar 6, 2019
