Found out how painful it is to lose key fob
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by chrism07924, Jun 3, 2007.
  1. chrism07924
    chrism07924 New Member
    79
    Bernardsville NJ
    <div class='quotetop'>QUOTE(Frank Hudon @ Jun 4 2007, 06:57 PM) [snapback]455254[/snapback]</div>
    I guess it depends on one's definition of "cheap". I've read about Merc/Beemer replacements, and they're beyond highway robbery; a case of zapping the rich for all they got. Well, I'm not rich, can't afford a Merc (if I could, I'm guessing the extra Benjamins for a fob wouldn't phase me).
    <div class='quotetop'>QUOTE(Pinto Girl @ Jun 4 2007, 04:27 PM) [snapback]455153[/snapback]</div>
    The real issue - it's ridiculously expensive to be stupid and lose your keys. Like, approaching $500, which is, ridiculous. That $500 cost doesn't fit the "crime".
    And that doesn't include towing costs. Towing! For Christ's sake. That alone is a pisser. Maybe it takes following a flatbed truck swerving around the roads with your Prius on top....and all for a gosh darn replacement *fob* (a bleepin fob!), to appreciate what a muck'd up, stupid policy/S.O.P. this is. Again, hand/arm in the air (we) were stupid, I admit. But, Toyota and *all* manufacturers need a more humanistic, customer friendly approach to what used to be a much less expensive physical key replacement process.
    And I don't intend to "keep complaining" to Toyota. My only complaint to them thus far was getting quoted one price by a dealer, getting an invoice, and then getting told a day later that it's another $100....because they miscalculated the labor. That's B.S., if nothing else, they should be able to tell me *immediately* what I'm looking at in terms of cost for the simple request of "lost all fobs, need new one". Actually, I could have told them...I gleamed as much off Google to get near their ultimate cost, and I'm not the one with a service center. And it's not like I am in any position to haggle, what can I do, camp out next to my car, which I can't start to go shop around for, say, $400 fob replacement jobs (and pay for tow #2)? Please.
  2. chrism07924
    79
    Bernardsville NJ
    <div class='quotetop'>QUOTE(galaxee @ Jun 4 2007, 05:57 PM) [snapback]455214[/snapback]</div>
    Interesting. To me, this makes little sense - why should a seed necessarily have to require the actual vehicle to be generated and retrieved. If it's a fixed number, that can be captured centrally. If it's a random #, that can be generated centrally. If it's an algorithm based on a seed, that too can be moved centrally. Either this was a money making scheme, or just plain bad design if you ask me.
  3. Swanny1172
    Swanny1172 New Member
    666
    I have. The key for my 2001 Mercedes ML 320 was $150 less than the cost of the key for my 2006 Prius.
  4. galaxee
    galaxee mostly benevolent
    9,810
    469
    MD
    well, the scantool is needed to program the immobilizer. there is no way around needing to connect directly to the immobilizer.
    the engine ecu needs to be written over, so to speak, in this case to allow for a new key when all are lost. there is no way to do this by internet or other non-direct-to-car connection.
    it's basically for theft prevention. you don't want someone who has stolen your identity to be able to steal your car too.
  5. Frank Hudon
    Frank Hudon Senior Member
    4,147
    <div class='quotetop'>QUOTE(Swanny1172 @ Jun 4 2007, 07:26 PM) [snapback]455397[/snapback]</div>
    maybe in the US but not in Canada.
  6. chrism07924
    79
    Bernardsville NJ
    <div class='quotetop'>QUOTE(galaxee @ Jun 4 2007, 11:05 PM) [snapback]455433[/snapback]</div>
    It all sounds fairly over-engineered. And somehow, I can't picture someone getting a hold of ones identity for the purpose of figuring out whether they have a key fob, going to a car dealer or mailing Toyota corporate for a hypothetical replacement fob, followed by physically traveling to their locale and then ripping off their car (additional car alarms, big dogs, etc, be damned). Hacking one's PC, stealing credit card info, etc? Sure.
    If I lose my pin for my credit card, I contact the bank and the bank sends me a new code in the mail (to the address they have on record), or new card if the card was lost. It would have been nice if it could be this simple. Or in the very least, not require physically TOWING ones car to a locksmith or dealer with a scan tool. I'm almost even okay with getting ripped off, I've accepted that as dealing with these sleazy car dealers. But transporting an entire car...for what amounts to a new key....that's stooopid.
  7. wyounger
    wyounger New Member
    69
    Atlanta, GA USA
    This is not even unique to the fob-type keys.
    Most new cars with traditional mechanical keys also have a transponder in the key-head that does basically the same thing that a Prius key does when in the slot. Manufacturers have started to just set aside the mechanical aspect since it was not as secure as the electronic part in the first place.
    Most Fords since 2000 or so have had a transponder key. Like the Prius, you get two when you buy the car. If you lose one, you buy a new blank key, have it cut to fit mechanically, and then go through a basic programming routine whereby you show the car that you have one good key that it recognizes and now you want it to recognize an additional key. Sounds familiar, OK. But if you lose both keys and have nothing left that the car recognizes, your only remaining choice is to replace the computer, at a cost a bit over a grand.
    I'm not going to get into the "how it should be" part of the debate but I will say that regardless of the make and model of the car, if it's fairly modern you should not put yourself in a position where there is only one key in existence that the car recognizes.
  8. Bill Merchant
    Bill Merchant absit invidia
    4,096
    85
    <div class='quotetop'>QUOTE(wyounger @ Jun 8 2007, 01:01 PM) [snapback]458251[/snapback]</div>
    This is not true. Here is Galaxee's comments on this problem. IT IS NOT NECESSARY TO REPLACE THE COMPUTER!
  9. chrism07924
    79
    Bernardsville NJ
    <div class='quotetop'>QUOTE(wyounger @ Jun 8 2007, 04:01 PM) [snapback]458251[/snapback]</div>
    For me, it goes without saying that one should not put themselves in a position to have only one key (or no keys). But shite happens, for reasons unknown. Ok, stupidity, but that's where the customer side of the story ends.
    To me, the other side of the story is *exactly* the issue of how it should be; car models and car company profits sink or swim on issues that effect the customer experience and cost of ownership. Hey, whatever, if this is how it's going to be for years and years to come, fine. But I have a sneaking suspicion that the car companies, including Toyota, will eventually change things so *at least* one doesn't have to tow their car physically to a dealership to get new keys made. Maybe towing isn't deemed a big deal, but it's not cheap, and AAA refused to take my car because I couldn't take it out of Park (I guess the guy had no dolly).
  10. pingman
    pingman New Member
    124
    the replacement FOB should cost an arm and a leg, for people who lost their brain and their keys
  11. chrism07924
    79
    Bernardsville NJ
    <div class='quotetop'>QUOTE(pingman @ Jun 10 2007, 06:04 PM) [snapback]459280[/snapback]</div>
    I guess that's Toyota's thinking as well. Well, here's to never losing anything valuable! :rolleyes:
  12. nwprius
    nwprius Member
    227
    35
    Security is the name of the game. The number of stolen cars is beyond belief. Now the Prius is becoming more numerous and there are valuable components involved so it is only a matter of time until they become a target. Hopefully our SKS will deter many thieves.
