Found the way to override Navigation without cutting wires.
Discussion in 'Gen 2 Prius Main Forum' started by driverx, Jul 13, 2005.
  1. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,339
    917
    251
    Surprise, AZ (Phoenix)
    Man, I wish I would have read this thread before I too got brave.
    I got here by clicking on the Load Application screen. The first US option seemed to do nothing, so I tried the second one just to see what it did, and now I'm stuck at the same point.
    What's worse is that at 40.6k miles, I'm out of warranty, and can't blame it on some sort of glitch.
    If you find out an easy fix, please advise.
    I'm hoping it's just a matter of which item it loads from the disc, and not flashing the NAV memory w/ a new app (or waiting to do so).
  2. HTMLSpinnr
    5,339
    917
    251
    What's worse is that I've lost the ability to use bluetooth as well.
  3. LungCookie
    LungCookie New Member
    67
    I've added a warning about this to the KB article.
  4. HTMLSpinnr
    5,339
    917
    251
    Spent some time at techinfo.toyota.com and that search turned up nothing.
    Also looked at the NAV DVD again - my guess is that it's not finding what it wants in LOADING.KWI - I was hoping it would be as simple as renaming an image file, and burning a temp DVD.
  5. HTMLSpinnr
    5,339
    917
    251
    Here's what I see now instead of a map.
    Phone buttons don't work on wheel, neither does voice. Phone screens somewhat accessible from info screen, however buttons are not active and bluetooth connection is no longer established.
  6. TCD
    TCD Junior Member
    97
    Northern, NV
    Howdy,
    Well if you have nothing else to loose, you may want to disconnect all battery power and let the car sit for an hour or so. I would HOPE that when you reconnect the power, everything would come up in a default mode. However, I think that you MAY still have to figure out how to reload a number of items that are not in the default ROM(s) and update other items.
    On the other hand, I believe that some folks have a NAV DVD from the upgrade process; maybe you could borrow one.
    This is a computer with wheels after all...
    Good luck!
  7. HTMLSpinnr
    5,339
    917
    251
    I've tried disconnecting the N2 harness which provides the power (one closest to the driver's door on LHD cars) for about 30 seconds, no luck.
    bretray mentioned that he noted a battery w/ a wire soldered to it. I'm guessing this will need to be disconnected in order to truly clear it. Unfortunately this probably means I'll lose my stored points, etc.
    As for bluetooth, there may be hope - I found a place to do a memory clear (in an effort to fix this) wihch may explain why that's not working - simply re-pairing my phone to the car may solve that.
    New Toyota manual disclosure - Warning, curiosity killed the NAV.
  8. HTMLSpinnr
    5,339
    917
    251
    Edited for clarity...
    FIXED IT :)
    Howto to follow.
    WARNING: Attempt this at your own risk!!! I take no responsibility for misinterpretation of these instructions which may lead to permanent damage to your NAV ECU or yourself. However, since you got this far in "breaking" your NAV, you're probably brave enough to fix it too!
    Steps:
    Pull NAV ECU:
    • Remove rear plastic cover by pulling plastic retaining clips/pins. I found two flathead screwdrivers helped with this.
    • Remove 4 8mm/philips screws, 2 on each side retaining ECU.
    • Remove 4 harness connectors at front of driver's seat.
    • You'll need to spread bracket just a tad in order to dislodge the ECU from the bracket.
      • Open NAV ECU, perform "fix":
        • Remove 8 screws from the bottom of the ECU.
        • Cover is held in place by 1 tab on each side that fits around a small bump on the top cover. Using a small flathead screwdriver, spread the cover at the bump. The ECU cover should then tilt up and come right off.
        • With the plugs at the front, the left board is the NAV logic, and the right appears to be the AVC-LAN interface and power supply. There is a ribbon cable separating the two. These boards should lift right out, as the cover screws are holding them in place.
        • At whichever location is easiest, lift the retaining clip at one end of the ribbon cable connecting the power supply board to the "logic" board, then gently pull the ribbon cable free. This effectively disconnects the battery backup from the ECU.
        • I also spotted a black momentary switch on the power supply board. This may also be a reset/backup power interrupt, however being a multi-layer board, I couldn't easily follow the traces to double-check. For safe measure, I press and held this for a few seconds as well.
        • Re-insert the ribbon cable, ensuring that it's aligned correctly. Push the retaining clip back down to secure the cable.
        • Replace the boards, ensuring that the boards fit onto the alignment tabs. The power supply board was a bit tricky here.
        • Replace the cover. I found that securing the screws over the power supply board first helped to keep it aligned as mine wanted to pop out of place.
        • Replace the ECU, reversing the steps of removal.
        • Power on. You'll see on the NAV screen: Loading application, do not power off.
        • I then saw the "Agree" screen. Success!
          • You'll need to restore all of your map points, but that's a minor inconvenience compared to the cost of a new NAV unit or a dealer visit. Hope this helps anyone else who was unfortunate enough to see what "loading" did.
            Sorry for lack of pics, perhaps the next person to attempt this fix could photo-document this.
            *mod edit: See this thread for pictures of the process:
            http://priuschat.com/index.php?showtopic=33878&hl=
  9. efusco
    efusco Moderator Emeritus
    19,891
    1,191
    Nixa, MO
    Were your BT numbers and pairing preserved or did you have to redo all that too?
  10. efusco
    19,891
    1,191
    Nixa, MO
    Oh, and Well Done!!
  11. LungCookie
    67
    Nice work!
    The warning I put in the KB article has a link to this thread in case anyone else gets into trouble.
  12. HTMLSpinnr
    5,339
    917
    251
    Honestly, because I went through and did a memory clear elsewhere (can't remember exactly where), I'm not sure if that action cleared the BT pairing and numbers or if the NAV reset cleared it. I'm unsure as because even though the NAV was horked for a bit, I was able to (via the info button) get to the telephone screen. The data was gone at that time.
    Perhaps the next person who trys this could verify.
  13. exhuman
    exhuman Member
    151
    Pasadena, CA
    Re: Found the way to override Navigation without cutting wir
    htmlspinnr,
    I gotta send a high-five your way. Congrats on the adventure and especially the fix!
    :clap:
  14. vitium
    vitium New Member
    Austin, Texas
    htmlspinner, now that you have the "fix" down, are you going to be trying anything else. I think everyone is very interested in what all of those buttons do.
  15. KTPhil
    KTPhil Active Member
    1,379
    You may also have to reset the region after the reset/load.
  16. HTMLSpinnr
    5,339
    917
    251
    I did have to reset the region, timezone, as well as all of my nav preferences (speeds, etc.)
    I am not willing to try any other loads for now, since it was a pretty involved process. Perhaps in the future I can experiment further to see if we gain/lose any functionality. However now that it's a "documented" fix, perhaps others may be more adventureous.
    I suppose next time I try I could also see if the momentary switch is a "reset" button.
  17. hnational
    hnational Junior Member
    24
    uptown, chicago
    drivrx,
    Nice hack for the override! Now my wife and i can find a taco bell once we are already on the road (POI name).
    And to htmlspnnr (Rick) you are one brave man - thanks for posting your fix!
    can't wait to try the override!
  18. aaf709
    3,862
    2022 Prius Prime
    Ditto! I'm sorry it happened to you, I'm glad you were able to fix it and thank you for being able to share the fix.
  19. onerpm
    onerpm New Member
    477
    MN
    wow, Rick; good on ya for figuring it out. that story tells me not to show my son the NAV hack. he's from the (video game) generation that doesn't read instructions, just plays!
    rpm
  20. bobm
    bobm Junior Member
    Gardnerville, NV
    We did the override this am, set the destination on the fly - works great! thanks!
    but . . . now the nav lady's voice is considerably less loud. we checked the volume and it's set about mid way with adaptive volume set to on. still, she's quite a bit softer.
    anyone come across this?
    bob
