Frame Damage in Maryland
Discussion in 'Gen 2 Prius Main Forum' started by Tlyke1983, Aug 21, 2007.
  1. Tlyke1983
    Tlyke1983 Red Sonja
    70
    Wisconsin
    So I was hit for the 3rd time in my Prius while it wasn't even moving. I was stopped at a red light and was rear ended by a monster sized Ford Explorer. This is in fact my 3rd Prius that was hit last Friday. I brought it to the Bodyshop today and they glanced at it and said it looked fine and could be fixed very easily. Then the woman opened my trunk. My trunk has not shut since Friday and when she opened it and saw how bent the inside was she sucked in her breath and goes Ohhhhhh, that is not good. She says it looks like frame damage and they may total my car. I'm not a mechanic or anything but can frame damage be repaired and would I even want it to be repaired? Also in the state of Maryland if there's frame damage do they automatically total a car even if it's not that bad? I would post pictures but I don't know how.
    If they do total it I'll be saying bye to this board. This car seems to be bad luck. It sounds crazy but every year since 2004 I've gotten a new Prius because people keep hitting it while it's not even in motion. This accident was the least traumatizing where as the other two my car was hit from the front while I was stopped at a red light and the other I was t-boned while I was waiting at another red light. Maybe I should just start running red lights. J/K
  2. kimgh
    kimgh Member
    297
    San Jose, CA
    <div class='quotetop'>QUOTE(Tlyke1983 @ Aug 21 2007, 04:01 PM) [snapback]499989[/snapback]</div>
    If the frame is bent, there is probably no way to fix it. Sorry!
  3. Tlyke1983
    Tlyke1983 Red Sonja
    70
    Wisconsin
    Are you sure they can't just heat it up and then straighten it out or something? This sucks.
  4. Doc Willie
    1,717
    142
    Out there, somewhere
    <div class='quotetop'>QUOTE(Tlyke1983 @ Aug 21 2007, 07:01 PM) [snapback]499989[/snapback]</div>
    It would be just as logical to give up driving completely.
    You do have my condolences, however. We love our Prii, and this has to be a major bummer.
  5. galaxee
    galaxee mostly benevolent
    9,810
    465
    MD
    some frame damage can be straightened, but the cost of the repair/whether it can be repaired successfully is what will determine whether it's totalled.
    our camry got plowed into when it was parked on the street one night, frame was definitely toast. we had to replace it. just around the corner from us, someone had the corner of their truck parked on the street clipped. the buick in front of them got scraped all down the side. and we live in a low traffic area... there are pricks all over the place, it's nothing to do with the car. trust me.
  6. statultra
    statultra uber-Senior Member
    796
    30
    Edison,NJ
    2001 Prius
    it probably can be repaired if its bent slightly, you can bring it to a frame straigthening shop for a slight pull, i have never delt with rear frame damage, but both my prius's ( salvaged) had front frame damage, and i took apart the frame in the front ( drilling spot welds ) heated it and straightened it, and then welded it back together from tthe holes from original spot welds. Both my prius's have perfect wheel alignment and no vibration issues. If your prius has frame damage past the rear wheel area ( protruding into cabin ) i suggest you total the car, usually this requires replacement of trunk floor and floor pans.
    if you can get it repaired do it, it wouldnt change the driving characteristics ( of course unless it is not straighten to specs )
  7. paulrubin
    paulrubin New Member
    32
    With unibody construction, as I understand it you don't have a frame per se. Only trucks and SUV's based on a truck chassis has an actual frame. With that said, I just got my Honda Element totaled from a rear end collision. From the exterior it also didn't look that bad and with the exterior panels taken off the initial estimate was $3400. By the time more was taken apart, it was nearly $9000 in damage. As I understand it, almost anything within reason can be fixed for a price but once you approach about 70% of the car's value they will total it, sometimes a bit less. The remaining working parts will get them much of the amount back so it becomes win-win for the insurance company.
    The bigger questions you have to ask are:
    1. don't necessarily count on everything they replace being new Toyota parts, especially since it's likely that since you were rear ended, you should be getting the other guy's insurance to pay (better for your rates and no deductible) but they don't care about your car, just getting you out of their hair.
    2. you may get a mix of used parts and non Toyota parts depending on lots of situations and the state you live in
    3. there's always the chance your car won't be what it once was in terms of driveability and safety regardless of what the body shop and insurance company claim
    3. and most importantly, this will show up on CarFax and if it's a fairly significant amount of damage, you can kiss your car's resale value goodbye unless you sell it privately to an idiot
  8. Tlyke1983
    Tlyke1983 Red Sonja
    70
    Wisconsin
    I just want my car back and for people to just stop hitting it. It's always these huge trucks who can't seem to see me even though my Prius' have always been red and these accidents have always happened in the bright daylight sun. I just don't want to have to go through the waiting list, ordering one with all the bells and whistles and starting car payments all over again. I haven't even had this one for a year yet. I got it in September of last year. SIGH. I would go into all the wonderful features but you guys already know the wonderful features
  9. paulrubin
    32
    <div align="left"> </div>I have a feeling it's just bad luck, nothing more, nothing less. I was driving the easier to spot more visible car in July and got whacked by a Hyundai Elantra that looked like an accordian in the front with smoke rising. 20 year old girl, probably on her cell phone. Such is life. I had 7 payments left and was planning on giving my car to my daughter after the car was paid off. Now all my plans have had to be altered and I'm still not sure what all the fallout will be. Plus I'm without my second car (wife's Odyssey is ok but I hate that thing) cause the insurance company capped my loaner at about 19 days and by the time the check finally arrived and I put together an order the other day and now wait for my '07 Prius it will be like a good 2-3 weeks without a second car. Maybe you need to get a Escalade :)
  10. Tlyke1983
    Tlyke1983 Red Sonja
    70
    Wisconsin
    This whole situation is making me want to cry and very very nauseous. I felt bad enough going back to the dealership the 2nd and 3rd time. If I have to go back for a 4th they may start making bets on when my next visit will be for another Prius. I'm also HATING the rental car I was given. A Mitsubishi Galant. Nothing against the car it's just not mine and it doesn't have any Prius features. After 2 days I'm already down a 1/2 tank. UGH.
  11. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    <div class='quotetop'>QUOTE(Tlyke1983 @ Aug 22 2007, 12:37 PM) [snapback]500331[/snapback]</div>
    Note to self: Don't drive in Maryland. Seriously, are the drivers that bad there?
    Tom
  12. Tlyke1983
    Tlyke1983 Red Sonja
    70
    Wisconsin
    "Plus I'm without my second car (wife's Odyssey is ok but I hate that thing) cause the insurance company capped my loaner at about 19 days and by the time the check finally arrived and I put together an order the other day and now wait for my '07 Prius it will be like a good 2-3 weeks without a second car. Maybe you need to get a Escalade"
    This is what I'm afraid of. Being without a vehicle for who knows how long. I have work and I just recently decided to go back to school which starts on Monday. I just want to crawl under a rock and not come out. And I bet the guy who hit me is just going on about his life with his big ol' Explorer knocking things over as he goes. HUMPH :angry:
    The first two people who hit me were on cell phones at the time and I don't know what this 3rd guy was doing. Bluetooth should be mandatory. The bad driving can be blamed on the Chesapeake. We blame it for everything else. ;)
  13. statultra
    796
    30
    Edison,NJ
    2001 Prius
    dont worry everything will come back into its place, really, life is long live it happily.
    i had a bad experience in maryland driving down to florida with a loaded 2000 lb trailer, a had a tire blowout on the trailer and no one would let me enter the right lane to exit, the rim ended up catching fire and luckily we stopped in time.
  14. Tlyke1983
    Tlyke1983 Red Sonja
    70
    Wisconsin
    <div class='quotetop'>QUOTE(statultra @ Aug 22 2007, 06:34 PM) [snapback]500643[/snapback]</div>
    Thank you for the kind words. They are definitely needed and appreciated. There still is no word from the Body Shop. I called today and they told me that they did not have an update. Why is it taking so long just to get an update on what's going on? Are they just holding my car since it's not my insurance so they can charge more?
  15. Neicy
    Neicy Member
    834
    Wakefield, MA.
    Everything happens for a reason. Is there a hidden message you're not hearing? I once knew someone who said she needed a vacation - she broke her leg and was out of work for 6 weeks. Doesn't make it any easier to deal with. I had a job I loved but got back problems and had to give it up. I was so depressed. Within 2 weeks my son was assaulted in high school and got two broken elbows and was in splints for about 2 months. And he is a drummer, so it was really difficult for him. But I got my answer to why that job didn't work out. I learned that I was exactly where I was supposed to be at that time. Be gentle on yourself - some things are just not in our control.
  16. qbee42
    18,058
    3,074
    Northern Michigan
    <div class='quotetop'>QUOTE(Neicy @ Aug 24 2007, 06:21 PM) [snapback]501761[/snapback]</div>
    No, everything happens, but that doesn't mean there is any reason behind it. If you look long and hard you can often find reason, but it's the same thing as seeing animal shapes in the clouds as they float by. You see what you want to see.
    Tom
  17. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    <div class='quotetop'>QUOTE(Tlyke1983 @ Aug 22 2007, 02:47 PM) [snapback]500485[/snapback]</div>
    Perhaps the bigger problem is multitasking in the car. When driving one's attention shouldn't be diverted by yakking on the phone--or any of the other thousand things people do instead of paying attention to their driving.
  18. Prudence
    Prudence New Member
    109
    Hudson Valley
    <div class='quotetop'>QUOTE(qbee42 @ Aug 24 2007, 06:27 PM) [snapback]501765[/snapback]</div>
    Exactly, that's the difference between happy and unhappy people, it's all in how you see things.
  19. patsparks
    10,664
    567
    Adelaide South Australia
    If frame damage couldn't be repaired there wouldn't be any such thing as a chassis bench which is used to pull the frame with the oposite force to the one that did the damage while a tech taps and heats until it's straight.
    Prius like all modern cars is designed to fold around you and protect you, I wish my insurance would buy me a new car each year. My insurance has full new car replacement in the first 18 months if the car is a write-off.
    If the accidents are someone elses fault you shouldn't even have an increase in premiums.
    My sugestion if you want to put an end to the inconvenience is move house or go a different way. Don't run reds and don't stop driving the safest car around.
    By the way, red, green, dark grey, and dark blue are the worst colours to see in poor light or if wearing cheap sunglasses. Yellow and white seem best.
    Daimler-Benz say white is right
    Daimler-Benz undertook research (before flourescent paints were used) that concluded that white was the easiest colour to be seen. White rated 86% in their tests while black, dark red and dark blue rated 4%.
    From http://www.ltsa.govt.nz/fascinating-facts/...le-colours.html
    From the same site
    How conspicuous is the colour of your car?
    According to Daimler Benz, the ratings for
    colour ranges from white - at 86% percent -
    down to black, dark red and dark blue at 4%.
    White 86%
    Light Ivory 71%
    Aqua Blue 71%
    Yellow 70%
    Pastel White 67%
    Off White 65%
    Maple Yellow 58%
    Signal Red 44%
    Autumn Beige 38%
    Carnelian Red 21%
    Red Green 21%
    Beige Grey 20%
    Grey 17%
    Blue 8%
    Deep Blue 5%
    Dark Olive 5%
    Balck 4%
    Dark Red 4%
    Dark Blue 4%
  20. Tlyke1983
    Tlyke1983 Red Sonja
    70
    Wisconsin
    My car is Barcelona Red. Very shiny and it was 12:30pm and the sun was shining brightly and there were no clouds. From my point of view there was no outside factor that caused him to hit me then just being human and not paying attention. After I was hit the light was still red while we talked about where to drive to so we were out of traffic.
    I'm not upset so much that my car was hit just that now is such a bad time for me to be going through this nonsense right now. I have a ton of other things going on and not having MY car is driving me nuts and the idea that I might have to go through the hassle of buying another car is just adding more stress on top of other stress. SIGH.
