Frayed High Voltage Wire
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by johnnychimpo, Jan 30, 2022.
  1. johnnychimpo
    johnnychimpo Active Member
    512
    111
    Monterey
    Well I have a new one. I had been seeing check hybrid system and simply reset the system and it went away for various reasons car wash, recent brake fluid spill etc stuff I figured I just got something wet that just needs to dry. seen it again today after carwash undercarriage wash and decided to inspect further and found this beauty. I suspect I did this when I replaced the trans and pinched this wire. I think I can get away with cleaning with electrical cleaner then sealing it with some heavy duty electrical sealant but I want something that is going to last. Any suggestions. I have used this and liquid electrical tape in the past but know that only lasts 4 to 5 years then fails. I was thinking window caulking or maybe valve cover sealant as it withstands oil and high heat. thanks in advance. High Voltage trans wire.jpg IMG_20220130_111828.png
  2. Air_Boss
    Air_Boss Senior Member
    4,139
    1,154
    New Yawk
    Did you pinch the cable with a jack? One conductor (maybe more) appears bare. If you are intent of trying to encapsulate it in place, instead of petroleum-based FlexSeal, you might try the type of liquid rubber used to coat tool handles, which would not require tape wrapping.
  3. rjparker
    rjparker Tu Humilde Sirviente
    9,590
    5,889
    Texas Hill Country
    Honestly you need a new cable. Maybe a junkyard part. That much damage will eventually corrode. It will also cause a hybrid failure for high voltage leakage.
    If I had to attempt a temporary repair, I would probably go with a direct burial ac voltage spice kit with a gel inside the housing or a resin molded version.
    3M 85-14 - Multi-Mold Power Cable Splice Kit - Max. Cable O.D. 7/8"
  4. ChapmanF
    17,326
    2010 Prius (profile)? Or v (forum)?
    Three conductors, so it's one of the stubby little MG cables (MG1 or MG2). Could just replace and call it a day. If it were the two-conductor frame wire going all down under the car, that would be a more annoying job.
    I've been partial to Plasti-Dip for electrical repairs, and its dielectric strength is 8,000 volts per mil thickness. But it's petroleum-soluble, so engine-compartment applications might not be the best.
  5. Mendel Leisk
    40,574
    I think I’ve noticed that same conduit on our 2010. It’s quite low, picks up spray from the wheels, and ours was starting to corrode the wire mesh sheathing. No damage though. I painted it with boiled linseed oil.
    is that exposed high voltage wire on the lowest cable? If the wire is not abraded, I think you could reseal it, maybe just lots of electrical tape and finish with that sealant. Do pull the high voltage disconnect switch.
  6. ChapmanF
    17,326
    Yeah, it's the slice into the orange insulation that's the bad news here.
  7. johnnychimpo
    512
    111
    Monterey
    Good point I will replace the wire with my old trans cable as they are the same what will I need to remove to pull this wire swap.
  8. johnnychimpo
    512
    111
    Monterey
    Ok I have the cable but upon further review it is impossible to get at the 10 mil bolts that hold the cable in place. They are directly next to the frame of the car so no access to get them out. so next best option is I see minor corrosion on the copper. so what can I spray or put on the xposed wire to 1.stop corrosion and 2. seal it and hope for the best.
  9. johnnychimpo
    512
    111
    Monterey
    Thanks for keeping me honest but access to the 10 mil bolts requires you to pull the trans. :(
  10. rjparker
    9,590
    5,889
    Texas Hill Country
    I would pull the transaxle if necessary.
    Details
    • 80 Shore D hardness
    • Has 16-minute gel time at 73 °F (23 °C)
    • Useful for splicing solid dielectric and oil-filled cables up to 8 kV
    • Withstands a temperature range of 32 to 266 °F (0 to 130 °C)
    • Elongates 4% longer than its original size for easy insulation or wrapping
    • Withstands a voltage rating of 8 kV or less (for splicing solid dielectric and oil-filled cables)
    3M™ Scotchcast™ Electrical Insulating Resin 4N, with nozzel and guard bag, is a 2 part, insulating and encapsulating, epoxy based, liquid resin that generates its own heat to cure. Compatible with solid/synthetic cable insulations and jackets, this resin makes an excellent insulator and sealer for cable splicing.
    3M™ Scotchcast™ Electrical Resin 4N A is a multi purpose moisture sealing resin that remains stable, even at elevated temperatures. The resin bonds to itself and to nearly all modern cable jackets. It allows you to splice solid dielectric and oil filled cables up to 8 kV and to jacket high voltage splices. This resin is used in 82 H, 82 B1, 85 14CP and 90 B1 Series splice kits. ASTM Approved and RoHS 2011/65/EU Compliant‎.
    https://www.3m.com/3M/en_US/p/d/b00039969/
    #10 rjparker, Jan 30, 2022
  11. johnnychimpo
    512
    111
    Monterey
    I guess the splice kit is going to half to do. I would need to gut the car to get at the bolts. water pump engine egr inverter and finaly the trans. urghhh.
  12. rjparker
    9,590
    5,889
    Texas Hill Country
    The 3M™ Scotchcast™ Electrical Resin 4N A linked above might be enough followed by some self fusing silicon tape. Basically you are trying to "pot" (encapsulate) the connection with the resin.
  13. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,080
    Columbia, SC
    Looking at the length of wire available in the damaged area, I don't know how you would successfully perform a splice.
    Personally, based on your discussion about access to the fasteners and the infrequency of "coding out", I'd be much more likely to clean the area as well as possible, make sure there's plenty of gap between the "hot" wires and the shield, do some minor repair to the damaged insulation, do some insulation of the damaged area, and then encapsulate that entire area to lock it all in place (as mentioned, "pot it") and to keep moisture out. You could likely fabricate some type of formwork around that entire area and just turn it into a block of rubber (or whatever material is chosen to pot it). Would likely last for the life of the vehicle.
  14. johnnychimpo
    512
    111
    Monterey
    (BEFORE ANY WORK REMOVE HIGH VOLTAGE ORANGE BATTERY SAFETY PLUG AND UNPLUG THE 12V BATTERY)
    So after a deeper look I found only the bottom cable insulation was cut and none of the internal wiring frayed. So I cleaned wires with Electrosol a delicate electronics parts cleaner. Then cleaned the outside of road grime. and applied battery terminal anti corrosion spray to the exposed wires. I let it dry then applied two coats black gasket seal the same stuff for the timing chain housing. I figured anti oil and heat resistant. Finally encapsulated it just for road toughness rhino line spray just to keep it from exposure till the 3m electro resin comes in. Confident in my work I started the car and sprayed it down with the water hose and no check hybrid system so call this a good stop gap till the 3m gets here. the gasket seal should just peel off as it don't bond will with the rubber insulation.
