Free 2010 Prius with 230k
Discussion in 'Gen 3 Prius Main Forum' started by RedPearl, Jul 16, 2019.
  1. The Critic
    The Critic Resident Critic
    3,193
    2,333
    CA
    Generally speaking, head gasket failures are caused by another issue. They do not fail on their own without another reason.
    Unless of course, you drive an engine such as ours where the head gasket is just under-engineered/problematic in the design.
    SFO and Raytheeagle like this.
  2. jb in NE
    jb in NE Senior Member
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    Any engine running 200K plus miles is not under-engineered. At some point in the life of any piece of mechanical equipment, some component will fail, and it will typically be the same component in a large number of samples. That doesn't imply that component is poorly designed, it's just the limiting item.
    #62 jb in NE, Jul 24, 2019
  3. The Critic
    3,193
    2,333
    CA
    True. But head gaskets are coated metal gaskets (MLS). You generally do not see other metal-type gaskets (exhaust gaskets, for instance) fail without another reason. Metal gaskets do not deteriorate in the same way as rubber gaskets do.
    Raytheeagle likes this.
  4. ILuvMyPriusToo
    ILuvMyPriusToo Senior Member
    780
    518
    Outside Philly, PA
    2024 Prius Prime
    Yes, my other car was a Subaru . . . :cry:
    fuzzy1, The Critic and bisco like this.
  5. Vman455
    Vman455 Senior Member
    540
    556
    The Middle
  6. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    My vote is to make the trip if you have the time. Stop and see the sights while you are already there. Sleep at Chateau Walmart (the 24/7 properties) or truck stops where you can buy a shower.
    Unless Dad is really out to screw you the car should last more than 3000 miles.
    ASRDogman and chronon like this.
  7. chronon
    chronon Active Member
    601
    106
    here and there aint be in frozen wasteland no mo..
    ha ha ha -- after a week of cross country and if it craps out, relationship may go sour - chances are Dad knows better than to chance the drive since the car is on it's last legs ... my experience is dads dont slike to be stranded and the chance of being stranded will likely not make the roadtrip in the car with dad something he will go for, but it all depends on the dad ...
  8. jb in NE
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    2,733 mile, 41 hours. That's four not so long days, or three long days.
  9. chronon
    601
    106
    if u got 2 people driving, 16 hr days, takeing turns every 2 hours , (both sleeping for 8)
    that's probably something that isnt gonna stay kept up for long - as the site seeing, breaks, rest areas mount up ...
    if people are taking vacation and flying back yeah, it makes sense -- if u have backup parts and tools -- i really wouldnt want to be digging into the HV bat pack to swap out a module pair on the lowest V block, but that's something i would (if i were doing the trip) have is a pair of modules , a 12V battery to swap out the aux if it fails, and an RC charger to bring the module pair up to the level of the others if the need arises --
    sense of adventure ... it's a rush .. ha ....
  10. Stangar
    Stangar Active Member
    174
    174
    Palmdale, CA
    Really? Your Dad offers you a free car and you don't want to go get it because of the mileage? Man, oh, man. What is the world coming to? I don't know whether to laugh or cry. Expletive deleted.
    bettergolf likes this.
  11. bisco
    52,855
    i thought it was because it was 3,000 miles away
    mikey_t likes this.
