For Sale FREE Gen1 Steering Rack, Lock nut failed
Discussion in 'Private Sales' started by howardc64, Apr 3, 2019.
  1. howardc64
    howardc64 Member
    150
    58
    Pacific Northwest
    Toyota recall service screwed up the lock nut replacement and it loosened. Steering rack doesn't auto return after turning (can't remember left or right but 1 side only). Other wise, the rack is perfectly working.
    If you know how to fix this lock nut (new one to bite down tighter on the threads, tack weld?), then this rack can work perfectly again. Or if you just need parts (rotation sensor). Here is detail on the design and how it fails
    Steering Gear Pinion Shaft Lock Nut Design | PriusChat
    Figure about ~$20 for shipping. I'm in Seattle if want to pickup.
    See attached pic.
  2. ChapmanF
    19,065
    Yeah, the pinion-nut recall replacement technician instructions were a bit of a white-knuckle affair. You get one chance with the new nuts, after which it escalates directly to replacing the rack.
