Free oil changes with Toyota Care
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by ETP, Nov 30, 2017.
  1. ETP
    ETP 2026/2021 Prime/24 Venza Limit/B52-D,G,F,H
    2,806
    1,170
    Auburdale FL
    Do the dealers use the same data base to determine if I get a free oil change? Reason I ask is that I get my service at another dealer in the same state.
    Thanks,
  2. IMkenNY
    IMkenNY Im just being nosy
    477
    303
    Tropical Buffalo NY
    Four Touring
    All your service records are on the cloud available to all Toyota dealerships.
    You personally can lookup dealer service records for any Toyota once you register the vin# at my mytoyota.com (nice tool for pre purchase information on a Toyota vehicle)
    m.wynn likes this.
  3. ETP
    2,806
    1,170
    Auburdale FL
    Site is down/ARGH!
  4. bat4255
    bat4255 2017 Prius v #2 and 2008 Gen II #2
    670
    269
    Dodge Co. Wisconsin
    2017 Prius v wagon
    The Toyota site worked great for a few months, then it died. I haven't be able to get on it for over 9 months.
  5. Lucifer
    Lucifer Senior Member
    1,014
    486
    Nh
    Ah ha, I thought it was just me locked out
  6. DonDNH
    DonDNH Senior Member
    1,711
    655
    Nashua, NH
    Four Touring
  7. bat4255
    670
    269
    Dodge Co. Wisconsin
    2017 Prius v wagon
    That's the site I was using. I tried again with the same result. I also tried resetting my password and here is what I got.
    "An error occurred. Please try after sometime!"
    Yea, I'll get right on that.
  8. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    At least they didn't want you to try some place else. :confused:
  9. farml1234
    farml1234 Junior Member
    ohio
    Four Touring
    I just checked my recommended oil change miles and Toyota care says 5000 miles , so how are you people going 10,000 miles
  10. krmcg
    2,592
    2,393
    Whittier, CA
    service every 5,000 - but oil changes every 10,000 miles.
    RCO and Raytheeagle like this.
  11. RRxing
    RRxing Senior Member
    2,563
    1,842
    NEPA
    The Maintenance reminder comes up every 5K (after reset.)
    5K maintenance is for tire rotation and "multi-point" check.
    Every 10K is for tire rotation, "multi-point" check and oil change.
    Raytheeagle and RCO like this.
  12. ETP
    2,806
    1,170
    Auburdale FL
    Change mine every time. Usually they have a 10-20$ coupon so it is cheap insurance. Also the new dealer has cameras on the oil change bay so I can see if they removed the filter. However I cannot tell if they put a new one in as it is all hidden in the drain tray. Highly suspect some oil changes did not do the filter as I could still see the oil on the stick. A good oil change you will not be able to see the oil on the stick. Hopefully they will be more honest with people watching.
