Free Prius project (left in the woods 5yrs)
Discussion in 'Gen 2 Prius Technical Discussion' started by Whitfimb, Nov 8, 2023.
  1. Whitfimb
    Whitfimb Junior Member
    My aunt gave me a 2005 Prius after her brother passed... This car has been sitting in a field at the edge of the woods for 5 years.
    We installed a new 12v battery and gave it a bath. It runs but has many warning lights on.
    Scan car with Autel MX808
    P0AFA
    B2775
    C1259
    C1310
    P0A08
    P3000
    HV battery Block 1 voltage keeps flipping
    +16.2 to - 16.2. (positive to negative)
    I have pulled and cleaned the HV sensing wire (block 1) + sensing wire harness plug & HV ECU. I also took the HV ECU to my local electronics shop for plug corrosion inspection & clean up. I have cleaned up the HV pack terminals, nuts, sensing wire terminals, and bus plates for the battery blocks and this far no change.
    How best to troubleshoot Block 1 voltage issue? Can I swap block 1 & block 2 sensing wires? If the problem moves then HV ECU or harness / if stays then bad block or cell.
  2. TMR-JWAP
    TMR-JWAP Senior Member
    6,236
    5,936
    Columbia, SC
    You have a problem in the sensor harness, plug or ecu/ecu socket. You can purchase a new sensor harness from Toyota for about $65.
    Whitfimb likes this.
    49,515
    wow, looks like she just left the showroom!
    Mendel Leisk and Whitfimb like this.
  4. ChapmanF
    15,693
    Is "HV ECU" the ECU you really mean here? The battery ECU is inside the traction battery; the HV ECU is behind the glove box, in the dash. (The "HV" in "HV ECU" stands for hybrid vehicle, not high voltage.)
  5. Whitfimb
    Ahh! Thanks. Yes, battery ECU
  6. pasadena_commut
    pasadena_commut Senior Member
    1,502
    452
    Southern California
    Don't be surprised if sections of the wiring harnesses have been chewed down to bare wires. There is just no way that a car sitting in a field that long hasn't been home to many generations of rodents. For instance, that headlight looks like a rodents nest. Don't turn on the headlights! If by some miracle that bulb is still intact and the wiring is good the heat might start a fire inside the housing.
    Check the top of the thermos bottle - some furry creature stored a bunch of acorns there in my car when it belonged to a previous owner.
  7. douglasjre
    douglasjre Senior Member
    1,885
    655
    Orlando, FL
    Mouse droppings inside car to go along with that headlight nest?
  8. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,186
    2,215
    Taylors, SC
    I'd pass and sell it to a salvage yard.
  9. JohnPrius3005
    JohnPrius3005 Active Member
    419
    227
    California and Hawaii
    You can get it working but it will take time, effort, money. Or some combination of the above. Car prices are crazy high so I’d say it’s worth it. Your starting price of zero helps. Good luck. A few helpful tools and pieces of equipment, sorting the good, experienced, knowledgeable advice from the opinions on PriusChat and you’re on the way.
  10. jdenenberg
    jdenenberg EE Professor
    3,852
    1,854
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Whitfimb,
    If you need the repair manual for your 2005 Prius, send me a PM and I'll reply with a link to download it from my web site.
    JeffD
    JohnPrius3005 and ColoradoBoo like this.
  11. Whitfimb
    Thanks! The large 2 volume set of Toyota Prius manuals came with the car.
    New voltage sensing harness from Toyota installed - this came with 2 large battery leads wires from each end of the battery bank to the solenoids. Meanwhile my Autel updated and I can no longer see individual battery cell voltage.
  12. Whitfimb
  13. Whitfimb
  14. Whitfimb
    5BF18ED9-4791-4600-9B4F-34DD45A97E7E.png 62490112-F915-43F0-B8D2-5AED2BF9BB07.png Sub code 591 work up. Voltage & ohm testing circuit integrity
  15. Whitfimb
    7371E219-A990-4FD7-8201-2DD811F86D17.png Sub code 123 work up.
  16. Whitfimb
    D7869113-4DA8-4F40-8F2F-940EAD07A233.jpeg A friend recently gave me one of these fancy Hybrid battery testers. I might have to see what this magic 8-ball says. I believe I have a battery cell issue and a dc/dc inverter signal issue. It will take some time for me to navigate my way to the proper pin out locations for 591 (the HV and inverter plugs)
