Freezing point -- Water in gallon jugs?
Discussion in 'Fred's House of Pancakes' started by cyberpriusII, Jan 2, 2017.
  1. MrMischief
    MrMischief Active Member
    426
    443
    Denver CO
    put the generator in the shed (or build a small insulated structure around it). Vent the exhaust outside, surround generator with the water jugs. the heat the generator puts out should be enough to keep the jugs from freezing solid.
    Prodigyplace and RCO like this.
  2. DonDNH
    DonDNH Senior Member
    1,711
    655
    Nashua, NH
    Four Touring
    I suspect your water jugs are plastic. Replace them annually to reduce the chance of contaminating the water from the plastic. Over time plastic can leach into the water.
    RCO likes this.
  3. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    You are right about the contamination, but as long as the water is changed every now and again there won't be much contamination.
  4. Prodigyplace
    12,544
    11,769
    Central Virginia
    It is for sale. He is getting a Prime
    2010 Level 2 | PriusChat
    After market additions
    • Receiver hitch, 1-1/4", 200 lb.
    • Garmin nuvi GPS (removable)
    • 110 VAC inverter wiring, 1 kW
    • Forward-backward dashcam with GPS recording
    • Full-size spare and lug-wrench turning jack
    • 12V air pump
  5. Lucifer
    Lucifer Senior Member
    1,014
    486
    Nh
    Rig the generator to run the water pump when needed.
    MrMischief likes this.
  6. bisco
    51,883
    move to civilization.
  7. Prodigyplace
    12,544
    11,769
    Central Virginia
    And get your water contaminated in an attempt to "purify" it.
    I'll stick with my tested well water, thanks.
  8. bisco
    51,883
    uh, don't mention well water. bacteria, ph, chlorides, a nightmare.
  9. Prodigyplace
    12,544
    11,769
    Central Virginia
    No chlorides & we had an extensive test done through the Virginia Tech well testing program. I have installed a filter to adjust the pH, though.
    Virginia Tech were the people whose testing exposed the Flint Michigan water issues.
  10. bisco
    51,883
    my ph is 6.3, what are you using?
  11. bisco
    51,883
    thanks!(y)
    Prodigyplace likes this.
  12. Prodigyplace
    12,544
    11,769
    Central Virginia
    I got the digital control valve because you can program the flush parameters. I think the size is a little overkill, so we do not flush the media as often or as long as normal.
    They have other options too.
  13. bisco
    51,883
    my well guy says this sometimes causes hardness, which will then have to be treated. any change in yours?
  14. Prodigyplace
    12,544
    11,769
    Central Virginia
    My water was extra soft anyway. It still appears soft, but we have not retested it. Perhaps your county cooperative extension service participates in a well testing program.
    Private Water Supply Protection in Virginia
  15. Prodigyplace
    12,544
    11,769
    Central Virginia
    They have an easy programming guide that they only distribute of you call them. It contains recommended default settings. See attached.
  16. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    I have to agree with post #5.
    If you've got prolonged temperatures below freezing...any water out in that temperature will freeze.
    In an unheated shed? Exactly how fast would be hard to determine. But with low's in the 11-12's and highs in the 20's, I'm going to say solidification of your H2O would happen pretty quickly.
    If keeping the water unfrozen is your goal, then storing the water in your house...I'm assuming the guest bathroom is at least connected to heated area's....is your best move.
    You want to keep the water from freezing outside in an unheated and relatively unprotected environment? You're going to have to wait until temperatures are routinely "above freezing" which is 32 degrees.
  17. bisco
    51,883
    thank you, i'll look into county extension service. meanwhile i have to talk to the board of health and dpw. my we'll guy suspects the chlorides are coming from the excessive salting they do in front of my house, and the only removal system is r/o, which is a poor alternative to eliminating the source.
  18. Prodigyplace
    12,544
    11,769
    Central Virginia
    Call Aqua Science to see what the recommend. They do customer installations in Rhode Island so their offerings are designed for straightforward installation.
    They have good customer support too. Their new order picker missed part of my order and they offered to overnight ship the missing part.
  19. wjtracy
    wjtracy Senior Member
    11,366
    3,608
    Northern VA (NoVA)
    If you had a 11w solar panel and 12v batt and inverter you could possibly have a heat source such as a light bulb under the blanket. That is my idea for heating a car overnite but I need to get a temperature measurement to see if it makes a difference.
    Or get a few of those hand heat warmers.
