Fresh P0301
Discussion in 'Prius v Main Forum' started by Untimely Mechanic, Nov 17, 2025.
  1. Untimely Mechanic
    Untimely Mechanic Junior Member
    St. Paul, MN
    Very initial stages of investigation: Prius v at 250k+ miles. Coolant slowly going down. No noticeable white smoke. MPG doing fine, at least lately. Car started making a brief rumble or shake, becoming more frequent (maybe once per trip). Sometimes at startup and stop-and-go traffic. Now code P0301. What are the odds this is head gasket failure?
    #1 Untimely Mechanic, Nov 17, 2025
  2. Brian1954
    Brian1954 Senior Member
    2,692
    1,076
    South Central PA, USA
    IMO, Very high probability.
  3. rjparker
    rjparker Tu Humilde Sirviente
    11,125
    6,980
    Texas Hill Country
    Pretty good.
    Do an egr block to eliminate a sticking egr valve (however egr would not cause loss of coolant) or move straight to a high quality articulating borescope when cold with the coolant pressurized.
    Car Care Nut HG Borescope at 660s
    Egr block flow test
    https://youtu.be/lFVNaDJ6HOI?si=lZjJK932oimbrx8R&t=238
    At about 10:15 in the video he starts talking about the egr valve letting "air" into the intake manifold. He means exhaust gasses.
    BiomedO1 likes this.
  4. Untimely Mechanic
    St. Paul, MN
    Would your guess be that it's in the early stages? My average MPG has actually being creeping up by tenths over the last few months. Moreover, I've owned the vehicle for 15-16 months but had it for about a year before noticing low coolant.
  5. BiomedO1
    BiomedO1 Senior Member
    4,633
    2,433
    Left Coast
    You ever monitor the ECT while traveling? Hopefully the previous owner didn't put 'stop-leak' into it to cover-up that issue.Has that electronic water pump ever been changed?
    If it turns out to be the HG; the engine may have been 'running hot' and popped that HG.
  6. Mendel Leisk
    42,361
    How long have you had it?
  7. rjparker
    11,125
    6,980
    Texas Hill Country
    Normally early stages are very occasional severe rattles without coolant loss. I would do something asap because of possible overheating, warped heads, bent connecting rods or worse.
    The famous "Hey Walt" video
    #7 rjparker, Nov 18, 2025
    Brian1954 likes this.
  8. Brian1954
    2,692
    1,076
    From post #4
  9. Untimely Mechanic
    St. Paul, MN
    Just over 20k miles and 15 months.
  10. Untimely Mechanic
    St. Paul, MN
    Right, I never requested a full Carfax report from the dealer. It was originally a CA car; I'm in MN. It would be good to know about service history.
    Would a failed water pump throw a code?
    And do Priuses not have an indicator light for engine overheating?
  11. rjparker
    11,125
    6,980
    Texas Hill Country
    Prius gen3 engines do have an overheating light but it is often momentary with low coolant. Monitoring the engine temperature with an aftermarket reader is useful before problems exist to possibly see normal 185-205f coolant temperatures move up. Sometimes they don't move up to the light's 248f setpoint, which again, can be momentary and missed with low coolant.
    No overheating code usually appears but a misfire code is common when you are past the early stages.
    Water pump codes can be stored but there are some "impeller dragging" situations where water pump codes do not occur.
    Brian1954 and BiomedO1 like this.
  12. Mendel Leisk
    42,361
    See that was previously disclosed, should read more carefully. Any 3rd gen or v, for sale with 220k miles, there's a decent chance it's being dumped with a stop-leak product in the engine coolant.
  13. BiomedO1
    4,633
    2,433
    Left Coast
    The Prius doesn't save or log over-temperature.
    The water pump will only throw a code if it there's a dead short or open in the current pathway. So if it's intermittently stalling, you won't know unless you notice the temp lamp flashing. PS; there's no accompanying alarm or beep sounds when this happens - you just need to notice it.
    A 3nd party HUD that plugs into your OBD2 port will remedy this.
  14. ChapmanF
    19,041
    There's a P261B code for when "Water pump speed is less than 900 rpm while the water pump assembly is operating (1 trip detection logic)".
    In 2011 and later, there's also a P148F code for when the pump goes too fast. Seems like in 2010 the engineers didn't think "pump going too fast" merited detection logic and a code, but then in hindsight realized it's probably not going to go too fast unless, say, the impeller has broken off or the coolant is gone, and those would be things worth knowing.
    Still, when they added the P148F code, they didn't make it light a warning light. o_O So you don't get any heads-up when that happens, but you might see the code if you connect a scan tool.
    BiomedO1 and Brian1954 like this.
  15. Untimely Mechanic
    St. Paul, MN
    I think a wise first step would be the block tester with fluid. Any pitfalls with that?
  16. BiomedO1
    4,633
    2,433
    Left Coast
    Sometimes you'll get a false negative.
    Do the bore-scope test. The best way to test is when the car is stone cold and the cooling system has been pressurized.
    I know some people can't find the leak or say there wasn't a leak, BUT the engine was warm and the aluminum had expanded, so the leak disappeared. Not following basic instructions isn't the test fault, it's the tester's fault.
    Good luck....
  17. rjparker
    11,125
    6,980
    Texas Hill Country
    If you are talking about a combustion gas in the coolant test it can give you a valid positive or negative. However on these engines it has been known to give a false negative.
    So if it's positive you have a leaking head gasket. If it's negative you really don't know.
  18. Mendel Leisk
    42,361
    IIRC it tests only for carbon monoxide in coolant, which is NOT the the way the 3rd gen head gaskets fail, at least not in the early stages.
    It's typically coolant leaking into cylinders, and borescope inspection of the combustion chambers (preferably with cooling system pressurized to accelerate leakage), is the usual method.
  19. Untimely Mechanic
    St. Paul, MN
    I haven't done any formal investigation on this yet (the car has just stayed parked). I have some specific questions:
    1. Do you have advice or know of videos to help a guy determine whether doing an engine replacement is even a rational choice for him? The deepest I've gone is valve cover gaskets on a Sienna, which has a tipped-back V.
    2. What are good engine sources, and how would you avoid repeating the same problem? I'm assuming a Gen 3 engine with updates or a Gen 4, but I imagine they both have their downsides. As one who will not be named and uses no punctuation says, "Pick your poison."
  20. rjparker
    11,125
    6,980
    Texas Hill Country
    The easiest swap will be a late model (2017-2021) low mile (50k) JDM gen3 Prius v/+/alpha engine as these come with accessories already installed and will fit properly - no wiring or coolant loop changes needed as typical when swapping in a gen4 engine. No reusing some gen3 parts on a gen4 engine to make it fit.
    A primer on jdm engine-replacement.
    A Beginner's Guide to JDM Engine Swaps – JDM Westcoast
    In this case you are not looking for added performance in a Prius. You want an engine that does not burn oil and obviously has the latest head gasket, intake and egr valve you get with a recent model year.
    Options
    Engine death rattle when starting | PriusChat
    #20 rjparker, Nov 20, 2025
