From a Prius Prime owner
Discussion in 'Prime Plug-in Charging' started by Marine Ray, Sep 20, 2019.
  1. bisco
    52,863
    i run a flat extension cord under my garage door for Christmas lights. there's no issue
  2. Salamander_King
    Salamander_King Senior Member
    11,024
    8,980
    New England
    Thanks. If you know the source for a 10/3 Gauge 25feet extension cord, please let me know. I looked, but could not find at that length or shorter. I actually only need 10feet, but that's even harder to find for 12/3 Gauge.
  3. noonm
    noonm Senior Member
    575
    595
    2018 Prius Prime
    Salamander_King likes this.
  4. hill
    9,039
    true
    What I did was bought a 25-footer on amazon, & split it in 2.
    [img="[url="[url="https://images-na.ssl-images-amazon.com/images/I/61F18VVvbGL._AC_SL1466_.jpg"]https://images-na.ssl-images-amazon.com/images/I/61F18VVvbGL._AC_SL1466_.jpg[/url]"]https://images-na.ssl-images-amazon.com/images/I/61F18VVvbGL._AC_SL1466_.jpg[/url]"]https://images-na.ssl-images-amazon.com/images/I/61F18VVvbGL._AC_SL1466_.jpg[/img]
    One for the boat, one for our generator. All I had to do was screw on a couple new plugs that liwes & home Depot sell
  5. fuzzy1
    10,713
    While Home Depot and Lowes appear to have 10 AWG with only 30A plugs, Amazon has plenty with these with the standard plug.
    And even a single 10 footer too.
  6. Salamander_King
    11,024
    8,980
    New England
    Really, I am not finding one at 10 footer. I found a few 25 ft ones, but neither is stated to be100% TPE (thermo-plastic elastomer) compound that remains flexible in EXTREME temperatures. One I bought tout to be "Tested in the harshest Alaskan weather conditions, the cords remain flexible down to -94°F!"
  7. Salamander_King
    11,024
    8,980
    New England
  8. Rob43
    Rob43 Senior Member
    1,373
    1,050
    VA, BMW Race Car, BMW R1200R, BMW 330Ci, Ford F350
    2013 Prius v wagon
    Let me know if you want me to build you a Perfect custom length or 10ft 10AWG pure copper extension cord.
    Rob43
  9. Salamander_King
    11,024
    8,980
    New England
    Can you make it in SJEOW TPE jacket for outdoor use that will stay flexible down to -94F? If you can, please PM me a quote. I have had and used heavy duty 10 gauge extension cord that is made of SJTW PVC, but they become stiff as a stick in a middle of winter outdoor. I need one that stays flexible maybe not down to -94F, but certainly down to -40F. ;)
  10. fuzzy1
    10,713
    This is 10 feet. It claims 'extreme temperatures', but then doesn't actually give the detail you ask:
    I was seeing many more choices at 25 feet, but didn't dig in for the other details you ask for.
  11. Rob43
    Rob43 Senior Member
    1,373
    1,050
    2013 Prius v wagon
    My current stock of 10 AWG is SJTW, but I'll briefly look into it & get back to you.
    Rob43
  12. Rob43
    Rob43 Senior Member
    1,373
    1,050
    2013 Prius v wagon
    This cord is the lowest quality on the internet...
    This is a Do Not Buy.
    Rob43
  13. hill
    9,039
    if you are below - 30°F, don't bother charging, as traction packs are much more inefficient - to the point where it isn't worth charging
  14. Salamander_King
    11,024
    8,980
    New England
    Thanks, guys. I looked up. SJTW code is for PVC jacket. It may be rated for extremely low temperature, but my experience is that they become very stiff in low temp. SJE or SE are code used for TPE jacket. I can buy the 10/3 SJTW one on Amazon made of PVC and see how they behave in winter. Certainly, except for a few months middle of the winter, PVC will be just fine.
    #34 Salamander_King, Sep 28, 2019
  15. Salamander_King
    11,024
    8,980
    New England
    OK, we don't get very many days of night temp below -30F. In fact, we probably have not had much colder than -20F in recent years. So, no problem in charging even in the middle of winter so far. However, I gave up charging whole month of last FEB because ICE would come on every morning when I start the car no matter what I did, and price of gas became ridiculously cheap, that it made no sense to pay for high electricity to run on EV.
    That being said, I want the extension cord to remail flexible at least down to -40F for safety measure. Even if I don't charge, the extension cord has to stay cold in an unheated shed.
    #35 Salamander_King, Sep 28, 2019
  16. Salamander_King
    11,024
    8,980
    New England
    Now, come to think of it. My PVC extension cord gets hard and stiff in winter, but OEM EVSE cord remains flexible just like the TPE extension cord I bought. Does anyone know what material is used for the Toyota OEM EVSE cord? It does not feel like PVC, but not sure if it is TPE or something else.
    #36 Salamander_King, Sep 28, 2019
  17. Rob43
    Rob43 Senior Member
    1,373
    1,050
    2013 Prius v wagon
    10ft of my 10 AWG SJTW = $49 Shipped.
    10ft of 10 AWG SJEOW = $69 Shipped.
    Rob43
  18. hill
    9,039
    1st - there's a difference between stupid & ignorant. If you've never been taught, that's not stupid.
    2nd - there are other variables that you didn't mention. For example, resistance increases when temperatures are above 95°f. There is also resistance at termination points. This is why some chop off blade plugs & install twist-lock plugs. There is also more resistance in lower strand wire. This especially comes into play here because some posts here indicate they worry about stiffness in cold weather. 99 strand #10 is way more flexible than low strand #12.
  19. bisco
    52,863
    watched the video again, not sure exactly what happened there (n)
