From o2 sensor to engine replacement in 10 days?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by FantasticalMagicOne, Dec 29, 2018.
  1. FantasticalMagicOne
    FantasticalMagicOne Active Member
    264
    150
    Pennsylvania
    Well, I got the O-Ring replacement then reinstalled the MAF. Then I took her for a spin.
    The car is still loud and is still not accelerating properly. The car struggles when accelerating up hill and on flat runs. The engine charges the battery any time my foot isn't on the gas pedal, but the battery drains quickly any time my foot is on the gas pedal.
    I drove about 10 miles before there was 1 purple battery bar, the check engine light, hybrid system warning light, and the master warning light were on. 7 of the 10 miles was highway and expressway, and I ended up on the tapered deceleration pavement marking, since I didn't have enough power to get off the exit. I had to force charge the battery and it took approximately 2 minutes for the battery to start receiving a charge. I had to force charge thrice more to get home. Once before I left the expressway (the 7 mile stretch) and twice on the road I live off of (3 miles uphill to get back).
    I ran the diagnostic and these are the codes that were thrown: [​IMG]
    P0A0F - Engine Failed to Start
    P0137 - Oxygen Sensor Circuit Low Voltage (Bank 1 Sensor 2) - downstream
    P3190 - Poor Engine Power
    B1421 - Solar Sensor Circuit (passenger side) - it's cloudy here today
    I turned off the engine when I was on the pavement marking and the engine started the 2nd time, so not surprised that code was thrown.
    The downstream O2 low voltage has come up before - it's the factory one I purchased from and had installed at the dealership - the catalytic converter was also replaced that day. ("Runs like a dream!" said the service manager :cautious:)
    Poor Engine Power makes sense, it's not charging the battery - we know this.
    Can this be caused by improper installation of the cat and sensor?
    Also, I moved the car last night to the front of my house (flat surface) from my driveway (incline) so that I could get a proper reading on my oil and discovered an overfill this morning. I also took note that the tip of the dipstick is darker than the rest (haven't seen that before). That being said, I note that the oil was changed a couple of weeks (maybe two) before I brought it to the dealership to replace the sensor (upstream) and there wasn't any noticeable change in the way the car ran. I know that an overfill can be very bad news depending on how much over it is, and I am unsure as to how much that is, but here is a picture for reference.
    Help?
    #221 FantasticalMagicOne, Jan 8, 2019
  2. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    Press the little snowflakes and get the subcodes
    SFO and Raytheeagle like this.
  3. JC91006
    16,936
    8,647
    I had to spend the time to read the beginning of this post, as I have forgotten what has been done to this car. Back in post #14, you had already cleaned the throttle body and MAF sensor, you did not have to repeat this if it was already done.
    1. The oil overfill is not that much, it shouldn't affect the engine.
    2. The oil does look darker than normal for something that's been changed recently.
    3. I read there was a muffler replacement, was that an original muffler that was installed? Was there a gasket (a donut) put in between the muffler pipe and the catalytic converter pipe?
    4. Did you reset your battery (disconnect the negative terminal for a minute) after you cleaned out the MAF sensor (the one you just did)?
    I'm at a lost how the parts you've replaced could have made this car run so poorly. Even the Toyota dealership seemed to have escalated this issue to someone higher in the food chain.
    When you're ready to start the car, put it in diagnostic mode and let it idle. See if the car can run on it's own without dying.
    Here's a video on how to get it into diagnostic mode
    padroo likes this.
  4. FantasticalMagicOne
    264
    150
    Pennsylvania
    Thank you for taking the time to look, I know this thread has jumped all over the place. I thought my mechanic friend (2nd opinion mechanic) had cleaned the MAF and TB, but wasn't 100% sure. So I checked them and did them myself, and aside from the amber part of the sensor on the MAF, the rest needed to be done.
    Regarding the darkness of the oil, I thought so too. I can use some suggestions on an easy to use jack, I'm afraid to use the one that came with the car, despite it being used several times by others. If I had one that was easy for me to use, and that seems secure enough to where I thought the car wouldn't fall on me (real fear), then I'd just change the oil myself. I know how to and where everything is, but I'm always afraid the jack won't hold.
    Muffler was after market replacing the original and yes to the gasket.
    Yes to the battery reset after the MAF cleaning, but before the test drive.
    I don't know either, but it seems to me that the factory parts (cat and downstream sensor) and labor should be covered somehow (like a warranty or something similar). The downstream sensor code has appeared a few times and telling me I have a dead engine is a great way to make money while not having to own up to the shotty workmanship.
    I don't think they expected me to know so much about the car (albeit I'm still learning), and likely still don't. I coach my other half (male) on what to say and they listen to him. They tend to feed me BS (see HV battery testing nonsense).
    I will watch that video later and follow up with the results.
    I did not know that I should do that, techstream being very new to me. I had to go run the diagnostic again. I'll post the results in a separate comment.
  5. Skibob
    2,912
    1,505
    Northern California
    Still has that oxygen sensor code. I wonder if they plugged it in right, or didn’t install it right and the wires burned on the exhaust pipe?
  6. FantasticalMagicOne
    264
    150
    Pennsylvania
  7. FantasticalMagicOne
    264
    150
    Pennsylvania
    I really don't know, but they aren't standing behind their work, and it's leaving me without a vehicle. I'm going to have to rent a car this week to get to/from work, but I feel like they should send a tow truck and fix the issue they caused while providing a loaner.
  8. JC91006
    16,936
    8,647
    I know where everything is on the car and I don't go under to change my oil. My mechanic does it for $10 labor charge and I just give him the parts. I don't really like being under 3000 pounds of steel.
    The aftermarket muffler is probably what is making the car sound loud. If you want to get it quiet again, you can just buy a OEM Toyota muffler from Craigslist. Nobody seems to want them and they go for nothing (but I wouldn't do anything until you get your car running correctly)
  9. FantasticalMagicOne
    264
    150
    Pennsylvania
    The muffler was on weeks before I brought it into the dealership and it wasn't this loud. Wish I knew about folks getting rid of them for nothing, every little bit helps. If I can manage to get it running properly and it's still loud then it's something to consider, but I suspect it's to do with whatever was done to my car by the "experts." This is the one I picked up: More Information for WALKER 54560
    I'm not too fond of the idea either, but after all of this, I'd rather not have anyone do maintenance/repairs that I can take care of.
  10. JC91006
    16,936
    8,647
    This info leads me to think oxygen sensor was not put on properly. That's why it's loud and you have a code. Maybe it's not tighten down. I would address this info with the Dealership
    Skibob likes this.
  11. FantasticalMagicOne
    264
    150
    Pennsylvania
    In the meantime, I can use some help with the information I posted in #226 - I'm not sure what I'm supposed to be looking at.
    Also, if anyone has experience/advice on how to proceed with the dealership, I'd appreciate it.
    Proving that my engine isn't loaded with sludge and doesn't need to be replaced is easy enough, but proving that something went wrong when they were replacing the cat and sensors isn't so easy. If they decide to stand by "you need a new engine" instead of fixing their shotty work, then I'm going to have to eat the cost of another 30 mile tow and then the cost of someone else fixing it. I can't keep spending money on work that I've already paid for.
    The engine was powering the battery just fine when I drove onto the lot, and I had to have it towed off the lot, after I was told by them, that "it runs like a dream." Twice I drove off that lot with the assurance that I was in a safe vehicle, and twice I wasn't. The 2nd time, my family was with me, and handing me the keys, with the car in the condition it was (is) in, was irresponsible and very dangerous.
  12. FantasticalMagicOne
    264
    150
    Pennsylvania
    I can call them tomorrow, but to talk to who? It was the guy in charge that fed me all this BS. He's the manager you ask to speak with when something like this happens. :(
  13. JC91006
    16,936
    8,647
    The loud sound probably doesn't have to do with the poor engine performance, but it's strange it would have both after you took the car in.
    If you can't get help from the service manager, you can escalate to the general manager, then to the owner. If nobody at the dealership can help you, you can call the 1800 Toyota corporate number and ask them to help.
    You can actually call the corporate number now and give them all the info, they'll be your advocate in communicating with the dealership.
    Skibob and FantasticalMagicOne like this.
  14. FantasticalMagicOne
    264
    150
    Pennsylvania
    Very strange, and if it's the sensor that's causing the noise then what's causing the poor engine performance?
    What could possibly cause the car to lose power every time I step on the gas pedal?
    What causes the engine to drain the battery instead of powering it?
    Is there anything from the upstream sensor, catalytic converter, and the downstream sensor the could be messed up/ put back together wrong/ accidentally or unknowingly leaving something unplugged? I really don't know, I've never had this happen before and I've never seen or read about it happening to anyone else.
    Good to know. I will call corporate now, I'm gearing up for battle and it'll be good to go in with someone on my side.
  15. JC91006
    16,936
    8,647
    Poor power issues can be these items you haven't covered
    Bad fuel injectors
    Bad fuel pump
    Clogged fuel filter
    Bad throttle body
  16. padroo
    padroo Senior Member
    2,763
    2,253
    If the loud noise is an exhaust leak upstream of the catalytic converter it gives the O2 sensors bad information and the engine computer will act accordingly. The location of the noise is important.
  17. JC91006
    16,936
    8,647
    Now that makes a lot of sense
  18. FantasticalMagicOne
    264
    150
    Pennsylvania
    It's in the front of the car. It's the engine that's loud. It's not a muffler issue.
  19. padroo
    2,763
    2,253
    Here is an article explaining what I was talking about but I have never experienced this.
    Here is where an exhaust leak can affect fuel mileage or engine performance. In order for an oxygen sensor to function properly, it samples outside oxygen and oxygen in the internal exhaust gases. There are small holes in the external part of the sensors where this sampling takes place. Anything like an exhaust leak or oil leak in the area of the oxygen sensor will prevent the sensors from sampling external oxygen properly, which results in the wrong readings to the computer. The computer must have accurate readings from the oxygen sensors to maintain the 14.7 to 1 fuel ratio. If the computer receives bad information, it is going to do bad things. This usually results in poor fuel economy and performance issues.
    Can A Bad Exhaust Cause Rough Idle?
    It wasn't clear, we were talking about mufflers and noise, thanks for clearing that up.
    JC91006 and SFO like this.
  20. padroo
    2,763
    2,253
