From o2 sensor to engine replacement in 10 days?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by FantasticalMagicOne, Dec 29, 2018.
  1. VFerdman
    VFerdman Senior Member
    1,200
    1,218
    Western Massachusetts
    I've been following the thread with interest, but did not want to add to the already busy stream of data. Until now.
    You asked about an easy to use jack so you can feel safe under the car. This is really, REALLY important. NEVER ever climb under the car that is supported by jack alone. That is a big no-no. Buy yourself a pair of jack stands at your local auto parts store, lift the car with a jack and lower it onto a jack stand placed at the appropriate support point under the car (location of such points can be googled). Only after the car is resting on jack stands securely should you attempt to climb under the car. In fact, once jack stand securely support the car, it is very safe.
    Presently, I would definitely climb under the car with a good light source and have a look see at the whole muffler/cat/O2 situation. It may be very obvious once you are under there. A loose O2 sensor, a leaky connection between pipes, etc. can contribute to the problems you are having. It sounds like the problems started after the dealer installed the upstream O2 sensor. I would start my investigation there. Downstream O2 sensor was next to be installed by the very suspect dealer. Inspect that next. Get the friend that installed the cat for you to come over and inspect his work. I am pretty certain your problem lurks in that area of the exhaust system.
    Good for you to learn to be independent of dealers and car mechanics. I have done so since I was 16 (many years ago) and realized that the only way to do things right on the car is to do them myself or at least to understand really well what exactly needs to be done in case the job is beyond my abilities. It's a good way to own a car. I've been maintaining a repairing my own cars since 1981.
  2. JC91006
    16,936
    8,647
    Lol I should've asked if the loud noise was coming from the front or rear. We've been chasing the muffler noises lol
    @theelectricme, here we come 250
    #242 JC91006, Jan 8, 2019
    padroo likes this.
  3. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    There is a gasket that is quite close to the 'engine' area (front exhaust pipe assembly), and not far from your right foot when sitting in the drivers seat.
    Here is an image that might help :
    Raytheeagle, JC91006 and padroo like this.
  4. FantasticalMagicOne
    FantasticalMagicOne Active Member
    264
    150
    Pennsylvania
    They said that the dealership would want to take a look at it, but only the parts are guaranteed (for 1 yr), not the work. That the 2nd opinion of a local mechanic isn't going to be taken into consideration, only another toyota mechanic. Diagnostic codes thrown outside of the dealership will also not be taken into consideration, only ones found by their technicians.
    Corporate stands by their dealerships, they are their partners, is what he said. They are independently owned, but they're partners and they stand by their diagnosis. Dead engine.
    I wish I dropped the $180+ on that damned sensor socket.
    I don't know what was done to the ICE while it was there, but I know something happened to cause my car to start accelerating poorly, and drain the HV of power while the gas pedal is engaged. The ICE no longer powers the battery, I know that., but I don't know WHY that's happening.
    The rep just kept trying to sell me a new car because mine is old, out of warranty, with a lot of mileage.
    I went in to have a sensor replaced, I walked out with a pricey new catalytic converter, the other sensor and the diagnosis of a dead engine (after they were paid, of course).
  5. JC91006
    16,936
    8,647
    I don't accept the dead engine diagnosis, they don't die like that.
    That advocate was horrible, maybe you should try again with another one tomorrow
  6. Leadfoot J. McCoalroller
    8,288
    7,802
    Pennsylvania
    2018 Prius c
    Just piecing a few bits together...
    So the loud sound is coming from the front?
    You also referenced finding something underhood that looked dark and wet, but turned out to be dry? Possibly carbon and ash around a leaking exhaust flange?
  7. FantasticalMagicOne
    264
    150
    Pennsylvania
    They're sending notice to the dealership and someone will contact me by close of business tomorrow. They're going to want to look at it, but I'm responsible for the 30 mile tow (the car didn't make it 10 miles without needing to be force charged, it'll never make it 30 miles, north bound). I'm also responsible for the cost of another diagnostic, and if it proves that they were at fault, I'm responsible for the labor because only the parts are covered.
    I went in for a sensor replacement and they killed my car.
  8. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    From the Techstream screen for the P0A0F code (post 226), the subcode is 204.
    Research the troubleshooting for that and see what you get.
    JC91006 likes this.
  9. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    Alternately now armed with these codes, I’d pay the $20 for 2 days at tech info and use the repair manual.
  10. JC91006
    16,936
    8,647
    @SFO
    Raytheeagle likes this.
  11. FantasticalMagicOne
    264
    150
    Pennsylvania
    Yes, from the front. And yes, I actually took more photos today and forgot until you brought it up. I shoved my hand all the way down and just shot at random. It's located in the front of the car on the passenger side. I don't know if it's carbon or not. I just noticed it was there. I'll try to edit them for better lighting and see what I can see.
  12. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    Next stop....300!
  13. FantasticalMagicOne
    264
    150
    Pennsylvania
  14. strawbrad
    953
    1,007
    I think you really need to focus on the P0137 code. The malfunctioning O2 sensor could be the cause of the poor engine performance. It's the one thing your car is telling you is not working right.
    Starting on page 05-137 of the link from SFO are some simple and clear tests for the O2 sensor.
  15. FantasticalMagicOne
    264
    150
    Pennsylvania
  16. Leadfoot J. McCoalroller
    8,288
    7,802
    Pennsylvania
    2018 Prius c
    nah scratch my idea. If that was on the front of the engine, then it couldn't have been the exhaust. As far as I know the exhaust is on the backside of the block of every version of prius.
    Doesn't mean the sound isn't an exhaust leak, just that it isn't the same thing you didn't quite have in that earlier picture.
    I'd say go back to working on the excellent suggestions in #255, that's something very direct and important.
    FantasticalMagicOne likes this.
  17. Patrick Wong
    18,210
    6,517
    Thanks for updating this thread with the outcome of your test drive. It is disheartening to see that your engine still has problems. I reviewed the screens that you posted in 226 and did not see anything that would be particularly helpful.
    It is very interesting to see that no engine misfire DTC is logged.
    I see that a helpful forum member, SFO, provided links to the relevant portions of the manual. Regarding DTC P3190, here is a full list of the possible issues per the repair manual along with my commentary:
    Air induction system - you tightened the clamp holding the air cleaner housing to the throttle body and were looking out for leaks downstream from the MAF sensor, right?
    Throttle body - you cleaned that
    Fuel pressure - we don't know how this is doing
    Engine - we don't know about this yet
    Mass Air flow meter - you cleaned that
    Out of fuel - I believe you said the vehicle has adequate fuel
    Engine coolant temperature sensor - the screens you provided show the coolant temp was 82 degrees C and started at 1.8 degrees C, which seem normal (if the ambient air temp is near freezing)
    Crankshaft position sensor - don't know for sure, however if the engine ran for 10 minutes prior to registering the warning lights, I would be inclined to say it is probably OK
    Camshaft position sensor - same as crankshaft position sensor
    ECM - same as crankshaft position sensor
    If this were my car I would check cylinder compression, to verify the pistons and valves are working correctly. 128 psi is the standard, the minimum allowable is 99 psi, and the difference between cylinders should not exceed 14 psi. Then I would measure fuel pressure which should be 44 - 50 psi.
  18. FantasticalMagicOne
    264
    150
    Pennsylvania
    The catalytic converter my friend put in has since been recycled and Toyota installed one along with the downstream sensor. My other mechanic friend (the one who gave the 2nd opinion) has kept an interest in this as well (he's glad to have to opportunity to check out and learn more about hybrids), so I've been keeping him in the loop.
    He didn't wait for me to finish texting him about tonight before he called and said - listen, this all started when you got the upstream put in, right? Yep.
    And it was after market? Yep.
    And then you had the cat and the downstream put in because that's what their system read? Yep.
    He said, at this point, he's willing to bet it's the upstream sensor and that the car was misdiagnosed after that. He advised that I pick up a toyota sensor and replace the after market one. Then, if the problems persist, check out the downstream, which would be covered under the 1 year.
  19. Patrick Wong
    18,210
    6,517
    Well, none of the logged DTC that you reported point at the upstream air/fuel ratio sensor. However since you've been complaining about the engine making excessive noise, it wouldn't hurt to inspect the exhaust manifold, exhaust pipe, etc. at the same time that your mechanic replaces the A/F ratio sensor.
    I would not expect the downstream oxygen sensor to negatively impact engine performance because all it does it report to the engine ECU the health of the catalytic converter.
