Front Brake Caliber Replacement HELP
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by PriusGuy32, Jun 6, 2019.
  1. PriusGuy32
    1,417
    514
    Harrison Township, Michigan
    My Brother in law tried to replace a bad wheel bearing on my Mother In Laws 2010 Prius, 70k miles. He ended up letting the piston pop out of the Caliber (dont ask me how - I wasnt there for that part), and brake fluid leaked out everywhere. The battery was disconnected the whole time. He ended up tearing the caliber piston seal, so I took over the job and am replacing the whole caliber.
    I have TechStream software and have owned 3 Pri. I have been wrenching on cars my entire life.
    Knowing the bleed procedure might be different than a non-Prius, I have read conflicting reports - some say you MUST have techstream, some say its not necessary.
    Can I get some tips on replacing the caliber and bleeding the system? Any advice is super appreciated! (y)
  2. ChapmanF
    18,849
    As you have Techstream, you're in good shape. As soon as you've replaced the caliper, just pull up the brake bleed utility in Techstream and follow the prompts. I trust the reservoir never got low enough to suck any air in at the head end?
    PriusGuy32 likes this.
  3. RightOnTime
    RightOnTime Senior Member
    791
    1,660
    183
    Kidnapped in OC, CA
    I have done both manually and with Techstream. I say Techstream all the way!
    iPhone ?
  4. PriusGuy32
    1,417
    514
    Chapman, to be honest, I haven't even popped the hood to check - but the puddle of brake fluid is very large, I would not be surprised if it did drain the master cylinder reservoir :eek:
  5. PriusGuy32
    1,417
    514
    Yes, I have an iPhone.
    Thanks for the info, I will use TechStream. I was kinda wanting to check the battery cell voltages and all the other fun stuff anyways.
    If the master cylinder reservoir IS drained of brake fluid, does that complicate things?
  6. ChapmanF
    18,849
    You'll need a bunch more fluid, and if any air might have been sucked in from the reservoir, then in Techstream's Air Bleeding utility, you'll have to pick the "ABS actuator has been replaced" option instead of just the "Usual air bleeding" option.
    RightOnTime and PriusGuy32 like this.
  7. PriusGuy32
    1,417
    514
    Ok so I just went out to the Prius, the reservoir had only about 1/2" left of brake fluid at the bottom. I topped it off to the top. Hoping it can be just a simple bleed process tomorrow, when the caliber is ready for pickup at the parts store. :confused:
    Rebound likes this.
  8. ChapmanF
    18,849
    Caliper! Caliper!
    Mendel Leisk and PriusGuy32 like this.
  9. PriusGuy32
    1,417
    514
    I am not editing the spelling just to bug you :p:p:p:D:LOL:
    RMB likes this.
  10. ChapmanF
    18,849
    If there's any chance air was sucked into the actuator, I would come down on the side of selecting the full actuator bleed, rather than just the "usual" bleed and hoping for the best. It may be a bit longer process, but better safe than sorry.
  11. PriusGuy32
    1,417
    514
    Sooooo today I came home, hooked up my manual vacuum pump, bled the driver side, finished the brake job and started the car. Brakes are working GREAT, no lights on the dash, everything is good. (y)(y)
    Thank you for all of your help!!
    RMB, jb in NE and Mendel Leisk like this.
