Front Brake Dusk Shield
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by lindylex, Mar 2, 2026.
  1. Mendel Leisk
    42,309
    A thin coat of fluid film instead?
  2. ASRDogman
    ASRDogman Senior Member
    8,055
    4,083
    Another quart of grease would work wonders....
    It's always easier to replace them the 2nd time.
    I always put anti-seize paste on the metal parts that mate.
    I've never had a hard time of remove old hubs.
  3. lindylex
    lindylex Junior Member
    Earth
    No need to worry as this does not impact breaking. After three days it becomes a coat of dust add even more protection. i did this to my cars and it has protected backing plate for years.
  4. lindylex
    Earth
    Not much grease is use, it just looks like much. Anti-seize is a great idea. Grease is much more economic.
    "I've never had a hard time of remove old hubs." cars in this area mostly require effort to remove their hubs.
  5. lindylex
    Earth
    That works too.
  6. ASRDogman
    8,055
    4,083
    I've seen worse. Removed worse, without a problem.
    Grease doesn't work as well. It will harden and eventually get washed out.
    You can use the brake anti-seize.
  7. CR94
    CR94 Senior Member
    2,823
    1,238
    Northwestern S.C.
    Some grades of grease (e.g., boat trailer hub grease) offer better wash-out resistance than others. That property should be listed in grease specifications.
