Front brake pads replaced only
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Sue Airabex, Nov 30, 2022.
  1. Sue Airabex
    Sue Airabex Junior Member
    Mechanic said my front brake pads were worn, but refuses to only change the pads. $800. Is it safe to just change the pads?
  2. ChapmanF
    19,037
    Did the mechanic state any reason for not just replacing the pads? What other work is in that estimate?
    Sometimes the rotors develop rust and that rust eats away the pads. Changing only the pads in that situation will eat away the new ones.
  3. Tombukt2
    Tombukt2 Senior Member
    13,864
    2,519
    Durham NC
    Even if you bought good rotors today 60 a pop top line pads say 60 bux set. It's about 55 min to literally slap those parts on car without lift . I've done the 10 and 13 no issues no bleeding.
  4. Mendel Leisk
    42,355
    He wants $800 USD to install just new pads? $250~400 is more typical. The Toyota pads, with a fresh shim kit and the clips at the ends, retail for maybe $150 USD. At most, and mechanics will maybe get discount. What kind of pads was he proposing to use.
  5. Tombukt2
    13,864
    2,519
    Durham NC
    Alaska has hi.prices. Maybe neighbor has jack . Do on nice day .
  6. alftoy
    alftoy Senior Member
    1,132
    519
    Saskatchewan, Canada
    Maybe get another estimate.
  7. SFO
    SFO Senior Member
    5,302
    4,252
    Northern California
    How many miles on the vehicle?
    Can you inspect your own pads?
    FYI : you're moderated until you've posted 5 times.
