Front Brake Rotors
Discussion in 'Gen 5 Prius Care, Maintenance and Troubleshooting' started by AWD-Canterbury, May 20, 2026.
  1. AWD-Canterbury
    AWD-Canterbury Junior Member
    Canterbury NH
    2023 Prius
    LE AWD-e
    2023 AWD
    The dealership told me I need new front pads and rotors. I've got no problem with the pads but I question the rotors. What is the minimum thickness that would trigger replacement, assuming there are no vibrations or shimmies?
  2. JJNY
    JJNY Junior Member
    27
    NY, NY
    2023 Prius
    Base AWD-e
    Due to Regen of brakes, the issue is often lack of use, not wear. I had a Prius fail inspection for bad brakes recently. My solution was to take it to a country road and stop from 70 several times in neutral so the Regen was off . It passed -
    mva, Rafsdhc6 and Winston Smith like this.
  3. Mendel Leisk
    42,351
    Eddie F likes this.
    52,858
    common dealer theft, be careful. how many miles on her? you should get well over 100k unless road salt has intervened
  5. Hammersmith
    Hammersmith Senior Member
    2,491
    2,547
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Nowadays, it's usually best to replace both pads and rotors at the same time. It used to be that the rotors were thick enough to be resurfaced 1-3 times before needing to be replaced. But today, automakers have thinned the rotors enough that it isn't really possible to do that reliably. After resurfacing, a rotor might fail spec or just barely meet it. And if it just barely meets minimum spec, it also means it will be below spec long before the next pad job. Plus, there aren't that many places that bother to do rotor resurfacing anymore; almost certainly no dealers. Besides the other stuff, the labor to resurface a set of old rotors amounts to the same cost as a set of new ones.
    BTW, a pad slap(changing pads without replacing or resurfacing the rotors) is not good practice. Over time, sand and other particles get between the pad and rotor and wear grooves into the rotor. When you put on a new pad, you now have a flat surface against a grooved one. All of those grooves reduce the contact area and lower braking ability. That's why making the old rotors flat again or getting new ones is important. You want maximum contact area to give maximum braking.
    Although I have to ask how many miles you've put on in three years? I just took my 2023 Limited in for it's three year service(I do my own maintenance, so I like to take it in once a year for a thorough inspection - not the "free" multipoint ones where the techs barely look at it because they're being paid peanuts for it if at all). After 36k miles, I still have 7mm all the way around. At that rate, I should have around another 20k miles left. I even wonder if they accurately measured them because I think another dealership had them at 9-10mm less than 5k miles ago. In any case, most hybrids should get at least 5-8 years/50k-80k miles(often much more) from their pads depending on usage. Replacing at three years seems odd unless you do a ton of hard stopping. If a dealership told me I needed new pads at anything less than 50k, I'd probably demand they prove it to me with a ruler that the pads are under 2mm.
    3mm = time to start planning (or change them now if about to go on a long trip)
    2mm = you're pushing it close (change them now if convenient)
    1mm = DO IT NOW
    Here's a CarCareNut video on Toyota brake service on modern cars:
    #5 Hammersmith, May 21, 2026
    Eddie F likes this.
  6. Hammersmith
    2,491
    2,547
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    BTW, here's the parts list for an LE AWD with prices. A basic brake job is not that hard. Get a quote from the dealer to see how much they want and compare it to the prices I give for parts. You may decide to do it yourself, or at least buy the parts yourself and have a non-dealership shop do the work for you.
    I'm giving four prices for every part. The first price is full MSRP. This is what your dealership will likely charge for the part. The second price is from dealerships I've found that have the lowest typical price for the exact same part. The third price is the current price from those dealerships because of a 15% off Memorial Day sale that's going on until Tues or Weds. The final price is a 25% off sale that happens on Black Friday nationwide as well as occasionally throughout the year at Southeast Toyota dealerships(AL, FL, GA, NC, SC).
    Front:
    $107.26 - $74.15 - $63.03 - $55.62 - 04465-16130 - Pads
    $104.28 - $72.09 - $61.28 - $54.07 - 43512-33150 - Rotor (need 2)
    $ 46.39 -- $32.07 - $27.26 - $24.06 - 04945-33300 - Shims (can reuse old ones if they're in great condition)
    $ 28.76 -- $19.88 - $16.90 - $14.91 - 04947-47030 - Clips (can reuse old ones if they're in great condition)
    So a front kit could cost you as little as $163.76 if you waited for a 25% off sale and only got the pads and rotors. If I had to buy today, I'd go $229.75 and get the pads, rotors, shims, and clips using the current 15% off sale.
    Rear:
    $79.27 - $55.07 - $46.81 - $41.31 - 04466-42080 - Pads
    $98.45 - $68.07 - $57.86 - $51.06 - 42431-78010 - Rotor (need 2)
    $46.89 - $32.42 - $27.56 - $24.32 - 04946-02120 - Shims (can reuse old ones if they're in great condition)
    $28.76 - $19.88 - $16.90 - $14.91 - 04947-47030 - Clips (can reuse old ones if they're in great condition)
    These parts are only guaranteed to be accurate for the AWD Prius and the Prius Prime/PHV. The FWD Prius uses some different parts and I don't have those part numbers handy. I'll search for them if anybody wants them.
    For regular sales, I typically use these two dealerships:
    autoparts.premierautoplex.com (Premier Toyota - North Platte, NE)
    autoparts.lewistoyota.com (Lewis Toyota - Topeka, KS)
    Those are the ones closest to me that also have the max discounts. You might be able to find ones closer to you that give the same discounts. But try not to choose one from your home state so you don't have to pay sales tax. (Unless you want to.)
    For Southeast Toyota dealerships, I've made this preliminary list of dealerships that seem to have the same discounts as the two above. I haven't bought from any of them yet, so I can't speak for their service. They're mostly Florida dealerships because I set my search radius at Miami so I would get only SET dealerships and not a mix of SET and regular ones. I stopped at 9 because I figured that would be enough of a list if I ever decide to buy from an SET.
    autoparts.southern441.com
    autoparts.treasurecoasttoyotaofstuart.com
    autoparts.bevsmithtoyota.com
    autoparts.getteltoyotaoflakewood.com
    autoparts.getteltoyotaofbradenton.com
    autoparts.miracletoyota.com
    autoparts.centralfloridatoyota.com
    autoparts.stadiumtoyota.com
    autoparts.toyotaofdecatur.com
    mingc likes this.
  7. Mendel Leisk
    42,351
    There's 3 mm difference between new and service limit, not bad. Screen grab from the attachment to post #7:
    Personally, with various cars over the years, I've changed umpteen pad sets, nary a rotor. That said, I should have, once, had one crack. :unsure:
  8. ChapmanF
    19,027
    I've had rotors resurfaced if they genuinely needed it, or more often just gone at them with wet 150 grit paper if that was all they needed, or just put 'em right back on, if that was all they needed.
    Tande likes this.
  9. Hammersmith
    2,491
    2,547
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Regarding resurfacing or replacing rotors, I'm only going to say this: The only times you're really going to notice flat pads on grooved/uneven rotors is when you need 100% braking force. But the problem is that when you need 100% braking force, you NEED 100%.
    A hybrid owner won't notice a difference between flat and grooved rotors after a pad replacement 95%+ of the time. Because you're either using the transaxle to brake or you're using the pads and rotors just to come to a full stop from low speeds. In the latter case, you only need a small fraction of the braking capacity to finish stopping.
    Like the CarCareNut says early in his video, there are a lot of strong views on the subject of rotors during a brake job, and you just have to end up agreeing to disagree. I just view the brake system as the second most important safety system after the tires. And I think about encountering a situation like a deer jumping out on the road, an accident happening in front of me, or a kid jumping into the street and just think the difference between having 100% full braking ability versus 90% or 95% might just be critically important when I least expect it. I may never need that last 5% of stopping power, but maybe I will. And I'm willing to spend the extra $200 every 8-ish years so that I have it.
  10. Mendel Leisk
    42,351
    FWIW, Toyota USA recommends a more in-depth brake inspection, specifically mentioning check of rotors, every 3. years or 30k miles.
  11. ColoradoBoo
    ColoradoBoo Senior Member
    1,352
    981
    Monument, Colorado USA
    What? Our 2017 Prius, still, has 4mm of pad left in the front...even more in the back. (60,000 miles on her)
    I'd have someone, ANYBODY, else look at the front brakes then after they tell you they are fine tell your dealer to pound sand.
  12. ChapmanF
    19,027
    The time I normally notice that difference is not when I brake, but when I inspect the rotor and drag my fingernail across it in the course of deciding whether I'm going to reuse it, sand it, have it resurfaced, or replace it.
    #12 ChapmanF, May 22, 2026
  13. douglasjre
    douglasjre Senior Member
    2,250
    751
    Null, NL
    If you want a pad slap you're going to have to do it yourself. If you ever magnafluxed a rotor you'd run screaming into the night. Can't imagine any repair shop w a Mechanic (schooled and certified)doing a pad slap
  14. AWD-Canterbury
    Canterbury NH
    2023 Prius
    LE AWD-e
    Thanks for all the responses and links .... my front rotors are closer to 28mm than 25mm.... I bought the car used just under a year ago, so I can't vouch for how it was driven .... surfaces feel smooth to the finger test ...I'll ask about parts at my local wholesale parts store and compare online toyota dealers. (my local toyota dealer has historically been too small to offer decent parts pricing, although they have recently changed hands to become a member of a larger chain.) .... I'll decide and I'll do what I do, myself.
  15. mva
    mva Active Member
    177
    105
    B.C. Canada
    2024 Prius Prime
    SE
    I have a good sized hill that I coast down in neutral, using the mechanical brakes, at least once a week to keep the rust off the rotors of my Prime.
    A little practice with the shifter and I believe this is no more hazardous than driving a manual transmission car or my motorcycle.
