Front Brakes / Calipers sticking temporarily?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by CharlesPrius, Aug 21, 2018.
  1. CharlesPrius
    CharlesPrius Member
    152
    59
    I thought it was a suspension problem, but I got 4 new struts/shocks 5k miles ago. Then my thought was that it's the front bearings (they probably are), but this specific sound only happens for a few moments after releasing the brakes, while driving. It's more of something I can "feel" than "hear" - just like something's slightly bumping in the front suspension area. But it goes away after a 10-20 seconds or so of driving resumption.
    Separately, I also think I need new bearings..?? I think that's the awful (yet, at this point, slight) creaking sound when going slowly over a large hump or culvert/drainage channel such as we have all over the place here in the desert. Especially while the wheel is turnt also
  2. ASRDogman
    ASRDogman Senior Member
    6,093
    3,273
    Maybe the pads are sticking to the rotor and when you move it leaves some material on the pad.
    After so many rotations it remove that material.
    The creaking sound could be a ball joint. Check the boots and see if they have torn and the grease
    has been washed out.
    A worn strut can also make a creaking sound.
  3. Grit
    Grit Senior Member
    6,148
    4,058
    Wilkes Land
    Relubing pins should always be first thing to do when your hear creaks, then go to struts, bearings and shocks.
    Raytheeagle likes this.
  4. CharlesPrius
    CharlesPrius Member
    152
    59
    Thanks guys. Struts/shocks should be fine, all were replaced 5k ago. They said control arms looked good too. I'm not in a location/position to be able to do underbody work but all of this info is great for when I bring it in to my mechanic.
  5. Mendel Leisk
    38,735
    How many miles on it? Have the caliper slide pins ever been relubed? If so, would you know what was used?
    Just one possibility.
