front bumper license plate kit + mounting
Discussion in 'Gen 2 Prius Main Forum' started by fcc, Jun 11, 2008.
  1. fcc
    fcc New Member
    245
    Nashua NH
    I think it is funny how I react with a new car and even the slightest
    perceived issue I make out of things.
    Well I finally got my plates and went to install the front bumper kit.
    I put it on, taking my time, thinking I had everything so perfectly level
    using the dimples. I did not have a drill to work with and since there was
    no directions on how to do it best I simply used the screws that came with
    it.
    After installing it I stepped back and noticed the most minor, minor, of angling. One can only notice it if you break out a ruler and compare the distance
    from the top to the plate mounting kit.
    Am I the only goof ball who could not mount that thing perfectly level?
    Am I the only one who gets too upset about such little things that 99.9%
    of people would never even notice?
    I just thought it was funny that I worried/got upset over a 2-3 degree difference in height of one side of the plate and was wondering if anyone else had a story like that
    to share with a new car! :)
    That is what I get for not having a level, a drill, and more patience! Sigh.
    Sometimes new cars are stressful when you try to be a perfectionist. I miss
    my old rust buckets that I could destroy in an evening and not sweat it
    one bit.
  2. FrankZ
    FrankZ New Member
    65
    Duluth, GA
    Oh Lord, you are just like my wife. She can detect the slightest bit off level in anything. I remodeled our kitchen and it almost led to divorce. I found that if she was not around when I was actually doing the work she didn't worry about things so much but if she was watching me do it, she would nitpick over an 8th of an inch drop in a chair railing over a 35 foot span. I finally just didn't do any work while she was home. It took longer that way, but we were able to stay married.
  3. KayakerNC
    KayakerNC Member
    399
    Eastern North Carolina
    So...using a file or a larger drill bit, enlarge the holes in the plastic bracket, giving you a little extra room to tweak.
  4. fcc
    fcc New Member
    245
    Nashua NH
    good idea and this is the exact reason this place is so useful!
    why didn't i think of that!
    thank you.
  5. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    Just let some air out of the tires on the high side until it's level...;)
  6. MagneticGrayIndy
    MagneticGrayIndy 06Prius;94M Miata;65Rambler770
    208
    Indianapolis
    uhm... if you use a level.. make sure the ground you're on is level first!
    then make sure any horizontal line on the car you're looking at (in comparison to the plate bracket) is also level..
    THEN see if the top of the plate bracket is level
  7. misslexi
    misslexi Member
    130
    Renton, WA
    They say if you strike your thumb while hammering, it helps to punch the nearest wall with your other hand, the new pain will equal, and cancel out, the first pain...
    I'm thinking if you were to remove the license plate only, then reinstall it upside down...:)
    Kidding aside, you are not alone, I'm the same way.
  8. hiremichaelreid
    hiremichaelreid New Member
    451
    Ottawa/Aylmer, Canada
    I
    I'm glad we don't need front plates here in Quebec, Canada. Probably saves me 0.1 MPG at 80 MPH ! :)
