Front defogger not blowing
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by GrimChaos, Nov 5, 2019.
  1. GrimChaos
    GrimChaos New Member
    Chicago
    Prius V 2012
    When I turn on the defogger there is no air blowing by the front window. I am able to switch from higher and feet vents (those work fine) but nothing comes out when I select the defogger. Also, when I turn on the defogger the sound changes a bit (the sound always changed, just mentioning it)
    Any ideas what it can be?
    Ways to troubleshoot or fix it?
    Thanks
  2. GrimChaos
    Chicago
    Alright, the servo behind the glove is working. So, something else broke.
    52,844
    maybe the door is jammed
  4. GrimChaos
    Chicago
    Any way to open it without taking the whole dashboard apart?
  5. bisco
    52,844
    maybe not, idk. a look at the service manual will describe the repair process
  6. GrimChaos
    Chicago
    Thanks for the reply,
    Any place I can find the service manual?
  7. bisco
    52,844
    techinfo.toyota.com
    and check the wiki page here for other possible sources
