Front defroster
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by larrys3255, Sep 13, 2015.
  1. larrys3255
    larrys3255 Junior Member
    2013 Prius Plug-in
    Is there any way to run "front defroster" and keep the circulation of air internal? Whenever you press the Front Defroster key it opens the air circulation. I really do not want to have outside air enter the car since I don't like breathing car exhaust.
    Thanks.
    Larry
    49,408
    what happens if you push the fresh air/recirq button, does it switch front defroster off?
  3. larrys3255
    2013 Prius Plug-in
    Nothing happens. You cannot turn the fresh air recirculation off when the Defrost light is on.
    I read in the Prius manual that the best way to defrost is to use fresh air and this is probably why it works this way.
    But I am really upset that Toyota wants to force the consumer to use fresh air instead of air recirculation.
    I think that I as the customer should be able to decide for myself how to do this.
    49,408
    agreed. maybe some manipulation of the intake vent?
  5. larrys3255
    2013 Prius Plug-in
    If I open the upper + lower ventilation switch, then I could change from fresh air to internal circulation. But I have not tested if that actually defrosts the front window. Does anyone know?
  6. Barbara R
    Barbara R Junior Member
    44
    2014 Prius Plug-in
    You may or may not consider this relevant, but I have found that defrosting the front window usually just takes a moment or two, so there wouldn't be that much external air to breathe while the defroster is on. Now maybe you're in northern Alaska, in which case, never mind. I'm in California.
  7. larrys3255
    2013 Prius Plug-in
    Barbara
    I also live in California but perhaps I am just too sensitive to car exhaust. Funny that when I was growing up in Philadelphia I thought that the fumes of buses and cars was how air was supposed to smell.! ;)
    Larry
  8. bisco
    49,408
    the lower with the defroster icon should work.
