Front dome/map light cover removal
Discussion in 'Prime Accessories and Modifications' started by thm8d, Feb 15, 2017.
  1. thm8d
    thm8d New Member
    Garden Grove, CA
    Anyone had luck removing their cover? I'm trying to replace my bulbs to LED and I can't figure out how to remove the cover without scratching anything. Seems almost impossible...
  2. Jasonheng15
    Jasonheng15 Lowered Prime
    65
    77
    I just used a small flathead between the 2 plastic pieces (left bottom corner) and it popped right out 20170215_210229.jpg
    thatoneraccoon likes this.
  3. YPizza
    YPizza Junior Member
    San Antonio
    I found that taking down the rear part of the central gray piece made it easy to remove the clear lens piece around it. Used the blunt nail file tool of a Swiss Army knife to get between the two pieces and release the tabs.
    Honda888, sdhzlgl and Toyota4Life like this.
  4. Tom_06
    Tom_06 Active Member
    609
    142
    Newark, Delaware, USA
    Least likely to break anything (lots of small delicate tabs) if you just use a door panel removal tool and take the whole module down. See the video. Be aware that it doesn't come off quite that easy the first time - they have had that one off a few times.
    Toyota4Life likes this.
  5. huskers
    huskers Senior Member
    2,549
    2,488
    Nebraska
    Some of you are like kids. Get a new toy and all you want to do it take it apart.
  6. Jasonheng15
    65
    77
    Its called mods. Why do u care what someone else does to their own car?
  7. estebinbin
    estebinbin Member
    184
    47
    Where do they sell the LED strip for the Prime?
  8. cjp767
    cjp767 Junior Member
    25
    35
    Gig Harbor, WA
    Let me add this-- I left my 2010 Prius at the airport for 4 days and accidentally left the inside light on. Luckily I had changed the inside lights to LED--- and the 12v battery was not dead when I returned and had enough power to engage the traction battery. I drove home normally
    Yep, I should have paid attention and shut the inside light off! That said, changing the inside lights to LED will be one of my first projects with my Prime... just in case.
  9. KyLien
    KyLien Junior Member
    27
    35
    Whittier, CA
    You mean this one? LED
  10. NeilPeart
    NeilPeart Hybrid & PiP Convert
    75
    69
    Bay Area, CA (USA)
    Good point, cjp767. I can't believe Toyota hasn't migrated to LEDs for all internal lighting for Gen 4. Perhaps the refresh or Gen 5 will get there?
  11. prius2017prime
    prius2017prime Junior Member
    Hawaii
    2023 Prius Prime
    XSE Premium
    For install instructions, you can search YouTube, “Toyota Prius LED Interior How To Install - 4th Gen 2016+” and pick up a set of LEDs from PrecisionLED or T-10 194 or 168 LEDs from Amazon
    Honda888 and Toyota4Life like this.
  12. Honda888
    Honda888 Junior Member
    SoCal
    2019 Prius Prime
    I'm having difficulty removing the map light assembly so going to order some auto trim removal tools (plastic) to see if that helps. Seems to be in there pretty good after trying to wedge it out with other random objects around the house... no dice
    I've already replaced the other interior lights excepted the dome light which requires a different type of bulb than the other ones.
