Front Drive Axle
Discussion in 'Gen 2 Prius Technical Discussion' started by BruceO, Nov 23, 2009.
  1. BruceO
    BruceO New Member
    Chardon, Ohio
    94 70K miles...
    My steering has started to shimmy just a bit so I took it to a local repair guy. He told me the wheels were OK and the front end was tight. He thought the problem could be the front drive axles need to be replaced ($560.00). He said I was in no danger if I wanted to wait until it got really bad.
    What do you all think?
    Thanks,
    Bruce
  2. EZW1
    EZW1 Active Member
    722
    Phoenix, AZ
    2016 Prius v wagon
    Four Touring
    I'm not a mechanic but a front end shimmy would likely be one of two things: 1. Wheel out of balance, 2. Loose ball or tie rod joint. I cannot see how the axle would be the cause unless there's something funky going on with the CV joints.
