Front driver side sagging a little
Discussion in 'Gen 2 Prius Main Forum' started by cooscoos, Aug 12, 2019.
  1. cooscoos
    cooscoos New Member
    Knoxville, TN
    Hi everyone: My front driver side is sagging about ¾" compared to the passenger side.
    I had replaced the struts with OEM units about 4k miles ago, and didn't measure the before/after. I don't know if the car has been this way since I bought it use in January. The car has 188000 miles.
    I have read a lot about rear sagging springs, which I did replace out of caution with the front struts.
    Has anyone had a front spring fail? I really don't want to rip the front end apart again and replace the springs.
  2. Patrick Wong
    18,210
    6,526
    Occasionally an owner has reported that part of a coil spring broke off due to corrosion. Take a look to see if that is the problem with your car. If it is, it would be a good idea to replace the coil springs on the front.
    If you don't notice a spring is broken then you might choose to live with the suspension as-is.
  3. PriusCamper
    PriusCamper Senior Member
    13,467
    5,436
    Pacific Northwest, USA
    Well... You car is 14 years old... And sometimes you can find a fix, but sometimes the wear & tear of all those years with the car heavier on that side due to mostly solo driving is gonna create that slight effect...
  4. cooscoos
    cooscoos New Member
    Knoxville, TN
    So I jacked it up a bit: Both springs are good, no broken parts.
    I'm going to continue to drive it as is because I usually just puts lots of miles on it and just rebuilt the front strut assemblies (new bumpers, upper/lower isolators, strut bearings, strut - even the little crappy white cushion from Toyota) and then aligned it.
    For anyone on the fence: I highly recommend doing front springs when you do a high miles strut job. I did the rears out as preventative measure but didn't see anything on the fronts. Now I know :)
    PriusCamper likes this.
