Front End Noise
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by calabrsn, Feb 23, 2015.
  1. calabrsn
    calabrsn Junior Member
    32
    RI
    Over the past 2 weeks, started having a whining noise from front end. It seems to be coming from the front passenger side. The noise starts at around 30 mph and increases with speed. Very noticeable at highway speed. Sounded a bit like tire noise. I did rotate the tires, front to back, but noise persists from the front. Any thoughts?
  2. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    752
    Delaware
    wheel bearing. weave side to side while its whining, and it should get louder and softer as you weave. if it does, wheel bearing is bad.
  3. alekska
    alekska Active Member
    435
    138
    Atl
    Sounds like a wheel bearing. Try to listen in turns. Depending on a direction of the turn the noise will get louder or quieter if its a bearing
    PS 69showelhead beat me by 1 minute :)
    Alex
    #3 alekska, Feb 23, 2015
  4. calabrsn
    32
    RI
    There is no change in noise level when turning side to side.
  5. Patrick Wong
    18,210
    6,516
    Another alternative is that a bearing within the transaxle is beginning to fail. For your sake I hope the problem is a wheel bearing, not the transaxle.
  6. calabrsn
    32
    RI
    Did turn out to be a front wheel bearing which I just had replaced at the dealer for $580.
    alekska likes this.
  7. 69shovlhed
    2,170
    752
    Delaware
    stealership is right... did you get a kiss with that hosing?
