Front End Parking vs. Concrete Bumpers
Discussion in 'Gen 3 Prius Main Forum' started by Sealawyer, Nov 13, 2009.
  1. Blue Prius Texan
    Blue Prius Texan Crazy? Nah...just humorous!
    78
    Fort Worth, Texas
    So THAT'S why I can't get a boyfriend!!!!????!!!!!
    I make 'em ride in the trunk.
    No more: "Why didn't you park in that space?" or "Why did you take THAT turn?" or "Slow down!" or "You drive like a maniac!"
    :lol:
    I think it's the fact that I have no depth perception, well, not like most people do..... hhhhhhmmmmmmmmmmm.........
    JUST KIDDING!
  2. viclavigne
    viclavigne New Member
    76
    Georgia
    Too many drivers have made it a habit to pull up until their tires hit the curb. Everywhere I park where there are curbs, half the vehicles are pulled so far up they partially block the sidewalk. :eek:
    My current vehicle (soon to be traded for a Prius) is a Honda Civic and it has the lowest front end of any vehicle I've owned. I can barely squeeze a lowered floor jack under its nose. I learned very quickly after taking possession that I had to say well away from curbs. Learning with the Civic will make it much easier when I take ownership of a Prius.
    Vic
  3. PriusCamper
    PriusCamper Senior Member
    13,472
    5,439
    Pacific Northwest, USA
  4. cupidchild
    cupidchild Junior Member
    89
    Denver
    45 psi? Isn't the recommended at around 33 psi ? What is the maximum psi limit for the tire?
    How much better mpg are you getting with higher psi?
    PriusCamper likes this.
  5. PriusCamper
    13,472
    5,439
    MPG will go up significantly... Tires can go up above 60psi before they're quick to pop... I pushed the crappy Integrities tires the car came with up to about 52/51psi before they had noticeable loss of traction. To me the sweet spot for great MPG and solid road handling is 48/47 psi on these tires. Hopefully I'll be able to go higher when I replace with Michelin. It all depends on the roads you drive on and how aggressively you drive. Reccommended psi is liability-driven, not performance or mpg driven. If you drive on gravel and potholed roads lower pressure is safer than higher pressure.
  6. Richard Norford
    Richard Norford New Member
    I was told to increase the PSI on my 09 to 42 F 40 R Anyone tried this? Help MPG? How about handling?
  7. Rebound
    Rebound Senior Member
    3,996
    2,645
    Portland, OR
    With the backup cam and tilted-down rear view mirrors, backing up is pretty easy.
  8. El Dobro
    El Dobro A Member
    7,106
    3,282
    I just take a guess how close I am and, so far, I've been missing the concrete bumpers by about a foot. Now, II worry about someone hitting the back of the car. :D
  9. Caledm
    Caledm Junior Member
    An extra-thick and long license plate frame made of rubber may solve the problem.
    I don't have the means to create one, but has anyone seen such a product on the market....or want to market one?
    Caledm
