Front Jack Point
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by gen2prius, Aug 19, 2022.
  1. jerrymildred
    jerrymildred Senior Member
    11,517
    14,171
    Tampa, FL
    Picture:
    Jerry's Evolving Thoughts on "new-to-me" Prime Premium | Page 28 | PriusChat
    Made from a singe 8' long 2X10.
  2. 2ndgenbestgen
    2ndgenbestgen New Member
    22
    usa
    jerrymildred likes this.
  3. jerrymildred
    11,517
    14,171
    Tampa, FL
    Have fun! But for rotating tires, you only need to raise one side at a time. The manual calls for front to back rotation, not a criss cross. That makes it a lot easier.
    2ndgenbestgen likes this.
  4. Mendel Leisk
    42,364
    I just put the whole car on safety stands, raise with front and rear jacking points. Appreciate it’s easier on 3rd gen.
  5. gen2prius
    gen2prius Member
    98
    28
    Sydney, Australia
    i-Tech
    I wonder why, maybe they didn't want to go into the depth of explaining directional vs non-directional tread patterns. The Australian version advises front back, but the back should cross at the front.
  6. jerrymildred
    11,517
    14,171
    Tampa, FL
    I don't think that would hurt anything, but I also don't think it helps enough to be worth it. This article from https://www.tirerack.com/tires/tiretech/techpage.jsp?techid=43 might be informative.
    As for my Yokohama Avids, I have about 40,000 miles on them and still have about 7/32" of the original 12/32" tread left just doing front to back.
  7. PriusCamper
    PriusCamper Senior Member
    13,468
    5,438
    Pacific Northwest, USA
    It's based on tread pattern:
    "Directional treads are designed to perform in the direction denoted on the tire sidewall only. They must always be rotated front to rear — no matter the vehicle they are installed on — so the direction of the rotation does not change." https://www.bridgestoneamericas.com/en/company/safety/maintaining-tires/tire-rotation
  8. Mendel Leisk
    42,364
    Does Toyota Australia say that?
  9. mr_guy_mann
    mr_guy_mann Senior Member
    4,120
    2,017
    NJ-USA
    That's used to be the "standard" rotation pattern for most cars in the US going back decades.
    Then it seemed like (single) "directional" tires were a thing for a number of years. Couldn't do the crossing side to side with those.
    Now I often see tires with "inside" and " outside". I still go with front to back unless the manufacturer wants something else.
  10. gen2prius
    gen2prius Member
    98
    28
    Sydney, Australia
    i-Tech
    The manual says so, can't find a PDF, here's a scan of the particular page.
  11. edthefox5
    edthefox5 Senior Member
    10,096
    4,840
    Clearwater, Florida
    I use the front jack points behind the bumper to jack the front up. There very strong.
    The jump points on the bottom edges of the fenders are really easy to bend.
    Once the front is jacked up I slide a car ramp under the front wheel. Do that on both sides when I'm done I just back the car off the ramps. I cant drive up on the ramps they slide on the concrete driveway.
  12. gen2prius
    gen2prius Member
    98
    28
    Sydney, Australia
    i-Tech
    You know what? It just occurred to me that the trolley jack comes with a short lever, I think it is for this precise purpose, to get it started in tight spots than slot in the long lever for more leverage.
  13. PriusCamper
    13,468
    5,438
    I had that thought as well at first... The half-llength lever wasn't short enough to make enough of a difference.
  14. Mendel Leisk
    42,364
    Happened to watch this lately. One of the final tests is ability of jack to start lifting when rolled way under.
  15. gen2prius
    gen2prius Member
    98
    28
    Sydney, Australia
    i-Tech
    You are right, just tried, did not change anything. There's a safety recall on the jack, I can return it, but there's no replacement in the price range can solve that problem.
    PriusCamper likes this.
  16. gen2prius
    gen2prius Member
    98
    28
    Sydney, Australia
    i-Tech
    Thanks for sharing that video, very informative, appreciate the time and effort that Todd had put in to make that video.
