Front left light out
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by ItsNotAboutTheMoney, Jun 7, 2012.
  1. ItsNotAboutTheMoney
    ItsNotAboutTheMoney EditProfOptInfoCustomUser Title
    2,287
    460
    Maine
    It seems my driver's side headlight bulb is out.
    OK, let's get untechnical. ;) It's the one in the obviously round outside light.
    That is, lights on just gives me a dim central light while high beam gives a good light.
    So, obviously I don't work on my car. ;)
    I just want to avoid an expensive trip to the dealer who'll insist that replacing the bulb is a time-consuming process involving removing lots of parts to get to the housing. But, I'd rather take it to my local garage.
    I've been told that in the Gen 2 you could squeeze your hand in to replace the bulb. Does anyone know if there are shortcuts in the Gen 3 for bulb replacement?
  2. RRxing
    RRxing Senior Member
    2,520
    1,791
    NEPA
    The driver's side bulb is easy to replace. It's the passenger side bulb that's a bit of a squeeze.
  3. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    The owners manual has a DIY maintenance section, which includes light bulb replacement instructions & bulb types. Very easy to do yourself.
