Front left tire bubble
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by bigmichaelkim, Jan 2, 2017.
  1. bigmichaelkim
    bigmichaelkim Member
    70
    US
    Hello, I took my car in for its 5000 mile service and while doing an inspection we found a tire sidewall bubble on the front left tire.
    I came to the conclusion that replacing this tire is necessary but had a small question.
    Is it recommended that I replace the tire with the oem tire and is it better for me to replace both front tires together? Regarding replacing both front tires, I would rather just replace the one problem tire because at 5000 miles I wouldn't think that the wear on the tread for the other side would be that serious and it would help me save money just replacing the front left tire.
    Any advice regarding this problem would be greatly appreciated!
  2. Mendel Leisk
    42,040
    Yeah I would just replace the one, at such low mileage. But, you are perfect candidate to take advantage of tire manufacturer's warranty against defects. I would follow up on that. The dealership should have volunteered to help with this I think. They can act as go between, give "professional testimony". What's the tire make/model btw?
    #2 Mendel Leisk, Jan 2, 2017
    RCO, alanclarkeau and krmcg like this.
  3. booke02
    booke02 Active Member
    391
    415
    Israel
    A good rule to follow: both tires on the same axle should match, i.e. manufacturer, model, wear
  4. bigmichaelkim
    70
    US
    Hi I appreciate both of your guys response.
    They are the oem tires on a 2016 prius 3 which after some research I believe is Toyo tires nanonergy a29. They said they would check if I have tire warranty but I am pretty sure I dont... could I argue that this could be caused by a manufacturing defect and will the dealership take my side or argue against me? I mean don't they get paid either way?
    Booke02, I appreciate the rule but I was just wondering if I broke this rule by only replacing one of them if it would be a huge deal. In a perfect world I can get them both replaced.
    Also I plan on just having the service done at the dealership I mean I will look into what they charge for parts and labor but as long as it's reasonable like labor price of around 80-100 and tire price near the discount price which is 87? I mean if they say the whole service costs 180 then I will have it done there if more than that unlikely I will have it done there.
  5. Mendel Leisk
    42,040
    Just for giggles check all the documents that came with the car. In the glove box? Often there's a warranty pamphlet from the tire manufacturer. This is the perfect manufacturing defect, btw. One thing, those tires might be hard to get in North America, not sure.
    Here's the Toyo USA OEM tire warranty pamphlet:
    https://toyotires-1524598101.netdna-ssl.com/media/1505/warranty_oe.pdf
    I would consider other places for the tire(s) swap as well, not to say the dealership won't be competive, but just keep in mind you're not obligated to use them. It's not Toyota warranty. Still, the dealership could your best ally in this, and it really should cost you nothing: they would be reimbursed by Toyo for install charges. The latter are typically $15~25 per wheel, btw.
    If the dealership is really indifferent to your plight I would first talk to the dealership owner, that'll likely wake them up. If not, just follow through, get done what needs doing, and contact Toyota about your experience. This is a near-new car with a tire defect.
  6. booke02
    391
    415
    Israel
    It's really just a safety issue. You want the both front (or rear) tires to behave in the same manner.
    (In this country, it is mandated by law that both tires on the same axle must be from same manufacturer and same specification)
  7. Mendel Leisk
    42,040
  8. bigmichaelkim
    70
    US
    Hey thanks guys! I didn't know the tire install would cost that little. Also I found this limited warranty for original equipment tire warranty pamphlet in my glove box hopefully it covers the price of the replacement.
  9. bigmichaelkim
    70
    US
  10. bigmichaelkim
    70
    US
    I will let everyone know of how it goes so that they can be more informed as well if this happens to them! Thanks guys!
    pjm877 and Mendel Leisk like this.
  11. Mendel Leisk
    42,040
    Get the dealership on this too. They owe you: you've just dropped big money with them, and they have an obligation to got to bat for you, do the legwork of reviewing the warranty, act as go-between with Toyo.
    #11 Mendel Leisk, Jan 2, 2017
  12. WilDavis
    WilDavis Senior Member
    2,493
    2,155
    49
    I always replace tyres in sets, or pairs at least, although bearing in mind the low miles in your case, you might get the dealership to help out (warranty? good-will?) - when you think that ultimately the tyre is the last thing between you and the road and every thing is riding (literally) on them, I think it's stupid to compromise on such an important link in the chain!
    RCO likes this.
  13. bisco
    52,518
    5,000 miles? if the others look like new, i would just replace the one with same model.
    RCO, kithmo and krmcg like this.
  14. Coast Cruiser
    Coast Cruiser Senior Member
    2,267
    2,571
    Pacific Coast Highway
    I can't wait for my noisy Toyo tires to WEAR OUT so I can buy quieter tires! And BETTER tires.
    I'm leaning towards getting the Michelin All Season.
    pjm877 and RCO like this.
  15. Mendel Leisk
    42,040
    Yeah, have dealership check depth gauge with a proper gauge (everybody should have one, they're $3~5), compare to spec'd new depth (9.7/32", per TireRack), go from there. I think the TireRack article I linked above suggests anything under 2/32" variation as aceeptable. With 5000 miles you likely only have 1/32" wear, if that.
  16. Coast Cruiser
    2,267
    2,571
    The dealer I go to, told me he can't get the original factory OEM Toyo tires. He said those are only installed on the assembly line. But he can get a different version of Toyo tire. But of course I don't know how honest he is being.
  17. Mendel Leisk
    42,040
    Coast Cruiser likes this.
  18. Coast Cruiser
    2,267
    2,571
    Thanks for posting that, Mendel. The Toyo is not a bad tire, but I would need lots more experience in the rain with them, to be sure. I've always had Michelin in the past on all my cars. And they performed very well in dry and wet conditions.
  19. bisco
    52,518
    put on 4 energy savers and sell the toy's on clist or ebay.
    RCO and Coast Cruiser like this.
  20. WilDavis
    2,493
    2,155
    49
    I used to have Michelin Energy Savers on my 2009 Gen II but they became very noisy and had developed micro-cracks in the side-walls, and were almost useless in the snow, so I replaced them with a set of Antares Ingens A1s for the summer (recommended by Town Fair Tires), and purchased a set of Blizzaks on a set of steel rims for the winter (see previous threads for full story). The Antares are very quiet, and great in the rain (…and they're about ½ the price of a set of Michelins) - …just sayin' :)
    RCO likes this.
