Front license plate bracket screws
Discussion in 'Gen 3 Prius Main Forum' started by Lou Bowski, Mar 14, 2017.
  1. Lou Bowski
    Lou Bowski New Member
    Ventura County, CA
    Hi all,
    I bought a used 2011 Prius that came without plates, originally from a state that doesn't require front plates. I ordered a bracket for mounting the front plate but it didn't come with screws.
    Question:
    What size/type of screws do I need for mounting the front license plate bracket?
    Thanks!
  2. CNYhybrid
    CNYhybrid Member
    158
    83
    Liverpool, New York
    Stop in at a Toyota dealer and ask the parts department and detailers. The former is responsible for the correct parts and the latter installs them on all new and used cars.
    Lou Bowski likes this.
  3. NavyLCDR
    NavyLCDR Active Member
    202
    127
    Lebanon, OR
    2024 Prius
    XLE AWD-e
    The bracket itself is held on by screws that just go through the plastic bumper cover. You can get a screw set from any generic auto parts store. There is nothing special about the screws.
    This is my mounting job with a generic bracket. The screws that hold the plate onto the bracket have plastic washers behind them to keep them from rubbing against the bumper cover.
    #3 NavyLCDR, Mar 14, 2017
  4. Mendel Leisk
    41,911
    If you've got the stick North American plate holder, there's two fasteners types with stock bracket.
    What holds the license plate frame to the bumper is a pair of coarse thread screws with 10mm hex head. It screws in like a sheet metal screw, directly into the front bumper plastic. At the corner/underside of the bumper is a similar screw, albeit a bit longer. Here's a couple of pics of both, license plate frame is on the right, with maybe 1/2" threaded length:
    Holding the license plate to the frame is a pair of fine thread domed head screws. This screw is roughly 9/16" overall length. For comparison: the rear license plate has the same style of fastener, albeit (again) a bit longer. They appear to be stainless steel. Here's a pic of both:
    First time I've had that off, lol.
    #4 Mendel Leisk, Mar 14, 2017
  5. Lou Bowski
    Ventura County, CA
    Thank you for the awesome replies.
