Front license plate mounting
Discussion in 'Prius c Main Forum' started by parked, Mar 3, 2018.
  1. parked
    parked Junior Member
    37
    17
    SF Bay Area
    My 2013's front license plate is mounted directly to the bumper cover in a slight depression with no bracket. It seems these cars were supposed to have a special bracket, but somehow I don't have one.
    For tight city parking, I'd like to have some kind of extra thick rubber bumper protector for the license plate bracket, but first I'd like to know what's underneath the bumper cover at the license plate attachment points. I haven't had any luck finding a photo or diagram online that adequately shows what's under the plastic skin. Is it a plastic insert then styrofoam energy absorber, or is there any kind of structure?
    I would probably get this "Luv Tap Bumper Thumper," but I don't think it'll fit in that small depression.
    I could also get some generic rubber bumpers and mount them with the license plate mounting screws. Nothing is going to look great, but I'm trying to keep it from becoming one of those city cars with a hundred license plate impressions in the bumpers.
    Any ideas? dr26.jpg rubberbumber1.jpg Screen Shot 2018-03-03 at 3.48.08 PM.png
  2. davidc83
    davidc83 Member
    116
    51
    Scottsburg, Indiana
    2015 Prius c
    Yes, move to a state that doesn't have a front plate
    Z917VL ?
  3. Brandon Most
    Brandon Most Member
    116
    70
    Dixon, CA
    2016 Prius c
    There is a styrofoam type energy absorber between the skin and the the actual impact re-enforcement. It's not quite as tight to the skin as my older (80's) Toyotas are though. At least not on my 2016. Worse case I would imagine that adding the plate frame bumper may flex the bumper enough to crack your paint on an impact. I doubt that would be the case though.
    Here's the parts break down for the front of the 2013:
  4. parked
    37
    17
    SF Bay Area
    Thanks, Brandon. I'd seen that diagram before, but I couldn't quite follow the exact attachment points. I think with that picture and the text (sadly, no more images) from this thread below, I understand the structure and attachment of the bumper skin and license plate.
    HOW-TO: Front bumper removal | PriusChat
    There's apparently nothing substantial behind the license plate, so any extra bumper that concentrates the force too much will just deform the bumper skin and styrofoam behind it.
    It looks like that Bumper Thumper tapers toward the rear and might actually fit in the little depression, so I'll give it a try. I might put a metal plate behind it to spread out the force from people backing into me when they park. Hopefully that Bumper Thumper is slightly more compliant than the bumper skin & styrofoam pad.
  5. Brandon Most
    Brandon Most Member
    116
    70
    Dixon, CA
    2016 Prius c
    Somewhere I have photos of mine with out the bumper on from doing the horn upgrade, but they must be on my other PC. I would be careful with a metal plate. If it doesn't run the full length of the bumper, I would think it would just add a stress point to puncture or bend on.
    parked likes this.
