Front license plate plugs/covers
Discussion in 'Prime Accessories and Modifications' started by Geoffrie b, Sep 22, 2020.
  1. Geoffrie b
    Geoffrie b New Member
    Ohio
    2020 Prius Prime
    I picked up my 2020 prime last night, had a great trip traveling the 5 hours back home. One of the things I wanted to change was to pull off the front license dealer plate, Ohio does not require a front plate. What I am left with is two square holes, are there plugs of some sort I could use to smooth the front bumper with creating a cleaner appearance? I could put a front plate on but would rather not. Thanks for the help
    Trying to fill/block these square holes. Picture from a simular thread[​IMG]
    #1 Geoffrie b, Sep 22, 2020
  2. Salamander_King
    Salamander_King Senior Member
    11,024
    8,972
    New England
    There is nothing I know of specific parts or accessory to plug the "square holes" you are concerned. I am sure there are ways to DIY mod you can apply but how hard it is, and how well it turns out, I am not sure. Every Prius Prime I have seen even one dressed for the Auto Show room has those "square wholes".
  3. Geoffrie b
    Ohio
    2020 Prius Prime
    I suppose if that is as bad as it gets, I'm doing well. Thank you
    Salamander_King likes this.
  4. Tips
    Tips Member
    128
    66
    Grand Forks, B.C. Canada
    2020 Prius Prime
    Just leave it as is! Some one will come up with a solution At least it looks better than how they did it in the past, they used a drill bit!
  5. Lue
    Lue Junior Member
    22
    Palmdale
    Any solutions yet? I just purchased my prime and the holes they made are horrendous! They just screwed in the large screw without easing into it and it bubbled the plastic. Almost feels like I may need sand the area, bondo and repaint the little square where they screw in.
    wondering if they make replacement pieces for this.
    Patric88 likes this.
  6. Lue
    Lue Junior Member
    22
    Palmdale
    Just for now, at least until I find a solution. I covered the horrible holes with electric tape. Can’t tell that bad from a distance but up close you can see how the plastic is messed up.
    if I don’t find a solution I’m sanding them down, using bondo and painting the little squares. Unless someone makes something to overlay here or cover the holes, till then though.... this is it.
  7. Lue
    Lue Junior Member
    22
    Palmdale
    Quick trip to AutoZone. Looks better than the tape ‍♂️
    pghyndman and jerrymildred like this.
  8. David9962000
    David9962000 Member
    141
    68
    2020 Prius
