Front Lower Control Arm bolt torque specs - to cross member subassembly
Discussion in 'Gen 2 Prius Technical Discussion' started by TroyF, Nov 19, 2017.
  1. TroyF
    TroyF Junior Member
    30
    Grove City, PA
    2018 Prius Prime
    What are the torque specs for the two control arm bolts - the ones that connect the control arm to the cross member sub-assembly?
    There is a horizontal front bolt that screws into a welded nut, and a vertical rear bolt that has a separate nut.
    I just spent 30 minutes scouring online and can only find torque specs for most of the other front suspension components.
  2. jjmerp
    jjmerp Junior Member
    51
    22
    Ohio
    Try This looks like 101 Ft Lbs
    SFO likes this.
  3. TroyF
    TroyF Junior Member
    30
    Grove City, PA
    2018 Prius Prime
    Perfect. Thank you.
  4. J Conner
    J Conner Junior Member
    26
    Austin, TX
    jjmerp, what is the attachment you included for? It does not look like a Gen II Prius suspension.
  5. TroyF
    TroyF Junior Member
    30
    Grove City, PA
    2018 Prius Prime
    Everything in the diagrams exactly matched my 2005 Prius, including torque specs for many suspension and sub assembly parts, which was just what I needed.
  6. Mendel Leisk
    42,368
    It's what I'm seeing in my second gen Repair Manual PDF.
  7. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    It’s the lower control arm without the ball joint attached.
  8. J Conner
    26
    Austin, TX
    Sorry, I must have had some other document open that was confusing me.
    Please disregard, and thanks for sharing the document!
