Front Lower Control Arm
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by richard203, Nov 20, 2023.
  1. richard203
    richard203 Member
    284
    61
    SF
    How do you guys align the bolt for it? im doing my passenger side right now and it took me like 2hr of struggle and still cant put it in.
  2. JC91006
    16,937
    8,647
    The secret is not buying aftermarket parts, they don't fit well
  3. richard203
    richard203 Member
    284
    61
    SF
    ya i didnt know it would be that bad of a fit, I guess thats why it cost $50 lol. I guess i'll give it another try tomorrow and if it dont work oem time. lol
  4. zeng
    zeng Junior Member
    45
    Kuala Lumpur
    You shouldn't have removed the 'bottom' bolt if you've already done so, it should be loosened, slightly.
    It's about 'skill' to pop in the top aftermarket bolt.
  5. richard203
    richard203 Member
    284
    61
    SF
    what u mean by "shouldnt have removed the bottom bolt"? u have to remove all the bolt to put a new control arm in and what aftermarket bolt?
    but anyways for those that having trouble with aftermarket lower control arm I managed to put it in. lucky i got a endoscope camera to stick that into the hole and line it up and then marking a few spot and then use the bolt to match the spot i marked.
    #5 richard203, Nov 22, 2023
    douglasjre likes this.
  6. zeng
    zeng Junior Member
    45
    Kuala Lumpur
    Thousand apologies as my mind wanders to eccentric front camber (aftermarket) bolts installation, and off topic.
  7. mr_guy_mann
    mr_guy_mann Senior Member
    4,120
    2,017
    NJ-USA
    When I am doing a control arm like this, I try to have the arm parallel to the ground (about the same position it would be in if it was installed and the car was on its tires).
    Leave the ball joint disconnected, then move the steering knuckle as far "out of the way" as possible. I remove the axle nut, a sway bar link stud nut, (and brake hose bracket or wheel speed sensor wire as needed). Then use a rope or ratchet strap to pull the knuckle back and out to get enough room to fit the control arm and bolts.
    That "flat to the ground" position for the arm is about where it should be when you tighten the front mounting bolt to specification. If the arm isn't at "normal ride height" when the front bolt is torqued, the the front bushing will tear and fail soon afterwards.
