Front Parking Light replacement. Help Please
Discussion in 'Gen 2 Prius Main Forum' started by dhman2006, Oct 20, 2014.
  1. dhman2006
    dhman2006 Member
    162
    27
    Boston, MA
    My front right (passenger) side parking light is broken and I can't figure out how to change the bulb. The left (driver) one is a simple twist and done, but the right one is just impossible. Does anyone know or can direct me somewhere that tells me how to replace the passenger side parking light bulb?
  2. JC91006
    16,673
    8,518
    They're both the same. Try using some (long) needle nose pliers and twist gently
  3. dhman2006
    dhman2006 Member
    162
    27
    Boston, MA
    Thanks for the reply. I tried that, but none of those worked. So I was wondering is there's any other way.
  4. JC91006
    16,673
    8,518
    There is a lot of heat that generate in those little lights, it's probably melted a little and on really tight. Twist left and right (wiggle) and see if it'll get loose. If you can get a bigger pair of pliers on there, it might help. Needle nose is not really wide enough. It's always counter clockwise to take them off
  5. Sergiospl
    Sergiospl Senior Member
    3,938
    1,351
    28
    What did you do to ur Prius today???? | Page 269 | PriusChat
  6. dhman2006
    dhman2006 Member
    162
    27
    Boston, MA
    Do you happen to have the manual or atleast page 269 of it?
  7. exstudent
    exstudent Senior Member
    2,214
    905
    Torrance, CA
