front rotors
Discussion in 'Gen 3 Prius Technical Discussion' started by diaedy, May 1, 2012.
  1. diaedy
    diaedy New Member
    Grafton,NH
    I bought a leftover 2011 prius and have less than 3000 miles. The front rotors have big ridges in both left an right but the rears are smooth as a baby's butt. Anyone else as I do not think this is right.
    Eddy
  2. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Shouldn't have noticeable ridges I wouldn't think @ 3k but I guess it all depends on how it was taken care of.
    Mine don't @ 31k.
  3. El Dobro
    El Dobro A Member
    7,106
    3,282
    Maybe there's some sort of build-up in the grooves in the center of the front pads.
  4. hlunde
    hlunde Member
    419
    75
    Because it was a leftover, the brake rotors most likely accumulated some rust while the car was on the lot. The surface finish will likely improve with normal wear. Dealer may not consider this a defect.
  5. El Dobro
    El Dobro A Member
    7,106
    3,282
    I would imagine the rear rotors would have had the same rust problems, too.
  6. hlunde
    hlunde Member
    419
    75
    True. So there has to more to this if it is a rust issue -- like the orientation during transport or storage.
  7. adamace1
    adamace1 Senior Member
    1,403
    193
    Charlotte, NC
    Pics Please?
  8. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    Mine was a leftover, too. Built 10/2011 and bought 3/19/2012. Mine had 50 miles on it (@ 24 mpg =:-0 ) and the brake rotors were pretty ugly at first. I'm at 2000 miles and they're getting better.
    If the brake feel ok in use I wouldn't sweat it.
