Front Side Marker Lights - change to turn signals
Discussion in 'Gen 3 Prius Accessories and Modifications' started by SDM44, Feb 20, 2010.
  1. bzyrice
    bzyrice Active Member
    805
    324
    West Palm
    Cool.. This may be in my list of free stuff to do!!
  2. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    Something to consider....
    The cheap azz stock blinker will tell you that you have bulb out by changing the blink rate. With the electronic type or any other "trailer" type blinker relay, you won't know if you have turn signal bulb out unless you look.
  3. ImeanGreen
    ImeanGreen Prius v Five BP Brigade #236
    547
    73
    Somewhere out there
    To do this, you need to cut and tap the negative parking light wire to the positive wire of the turn signal wire. I've just done this on my 11 CRV a few weeks ago and my 05 sienna years back with no problem. As a disclaimer, do it at your own risk. No diagram needed. BTW, this will be my next project very soon. here's a video of it. Sorry can't upload link. Go here for video. http://youtu.be/YiprEq3LkKQ
  4. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Sounds simple and I will look @ your vid when I get home tonight. Thanks!
  5. SubCode
    SubCode Senior Member
    739
    1,341
    what kind of bulb is it im confused is it a 168 or 194?
  6. xliderider
    xliderider Senior Member
    8,140
    3,278
    Honolulu, HI
    168, 194, T10, etc. are all interchangeable.
  7. SubCode
    739
    1,341
    Thanks xliderider!
  8. capolihu
    capolihu Member
    101
    76
    Mont
    I cannot see the photos. Is there any way to re-link them or some other thread has the mod described? would be awesome!
    Thanks
    #28 capolihu, May 4, 2018
  9. Tom Kat
    Tom Kat Junior Member
    I did this with a normally closed relay. The coil of the relay is tapped into the turn signals positive and negative and when the relay is on it cuts power to the side marker for the reverse blink.
    Here’s a video:
    I’m thinking of also adding a side indicator below the hybrid badge.
    Burna J and Putu Ariawan like this.
