Front Strut Bellows Split Boot?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Dan0, Apr 21, 2025.
  1. Dan0
    Dan0 Junior Member
    25
    TN
    I've seen videos on replacing CV Boots with a "Split" Boot. I was hoping to find a Split Boot For The Front Struts. Is there such a product, or a way to replace just the boot without having to take everything apart?
    Thanks
    #1 Dan0, Apr 21, 2025
  2. ASRDogman
    ASRDogman Senior Member
    8,066
    4,086
    They don't work very well. I used the on the old real volkswagens. They don't last.
    It's not that hard to replace the outer boot. You just need to have a vice to hold axel in while
    you smack the joint with a 5# or more hammer to pop it off.
    Slip the old boot off, new one on. Clean and grease the joint and pop it back on.
    There is a "c" clip that pops into a groove on the axel.
    Dan0 likes this.
