Front strut replacement on a 325K mile car
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by VFerdman, Jun 17, 2026.
  1. VFerdman
    VFerdman Senior Member
    1,200
    1,218
    Western Massachusetts
    I am in need of some front struts, I think. I have driven on New England post-winter war-zone like potholes in this car since 2017. I am the second owner and I bought the car in 2017 with 175K miles. It already had, according to previous owner's records replacement "quick struts". I assume Monroe quick struts, but the documentation does not mention "Monroe", just says "Quick Struts". I know Monroe uses that moniker, so I assume I've been riding on Monroe quick struts all this time. I've been satisfied with them. Now this car has 325K miles and is riding harshly, though steering and handling are fine. I am wanting to improve the ride, but really do not see the point of going with KYB, which are $170 per side, whereas Monroe Quick Struts are $70 per side. I am talking the strut+spring assembly as I am going to DIY this thing and do not want to deal with spring transfer. Is there anything wrong with Monroe? I know KYB is the OEM and probably much better product, but I am looking for cheap and effective. This is not a Lambo (like my other car :) - kidding). If I've been riding on Monroe all this time, I am fine with that. I would rather save $200. But if there are some horror stories out there associated with Monroe Quick Struts for 2007 Prius, please let me know.
  2. Leadfoot J. McCoalroller
    8,289
    7,802
    Pennsylvania
    2018 Prius c
    A Prius is never going to be that smooth on rough roads. New struts are absolutely needed if you are having trouble controlling the car during hard braking.
    Less dysfunction than that? Might not be worth it.
    You could theoretically get even-quicker KYB struts for less- used assemblies from a car that got rear-ended or T-boned with fewer miles than yours. car-part.com is a database that may help you find such nearby.
  3. VFerdman
    1,200
    1,218
    Strangely enough, I have no control issues at all. The car drives and handles fine. Every now and again I hear some noise when accelerating from a hard left turn. Not even sure if it's the front or rear, it's hard to tell. Other than that the car handles solidly. Just really rough (much rougher than before) on bumps. Steering is straight also. Oh, one more thing I forgot because it happened on VERY cold days in the winter. When it's well below freezing, those (now rare) super-cold days the car feels like it has no suspension and rides on solid rods. Like shocks are not compressing at all or very little. Then after driving a bit and warming up it becomes a bit more normal. This only happens on very cold days. Other times it's normal, but sloppy and harsh.
    I am not sure I can get front struts cheaper than $70/side and I do not have a good feeling about buying used suspension from a junk yard. Just does not seem like a good idea. There is a significant amount of work involved in replacement and if I end up with crap, all that needs to be repeated. I would much rather get new, known good strut assemblies. If the car was newer and not super rusty (another story), I would probably splurge for KYB, but as it is, I am seriously thinking Monroe.
  4. Leadfoot J. McCoalroller
    8,289
    7,802
    Pennsylvania
    2018 Prius c
    I'll admit, I made the suggestion mostly because I've never seen a quick strut assembly made from quality parts. In the beginning the idea was to save the costs of labor (and especially liability) by having the tricky work involving spring compressors done in distant places where they could get away with it.
    Later, we started seeing heavy use of counterfeit parts in these assemblies.
    Personally, I'm left with zero confidence in what is presently offered in that market but it has been a while since I took a close look. Things may have gotten better.
  5. VFerdman
    1,200
    1,218
    I am looking at RockAuto, which I have had good luck with as far quality of parts. I hear you about lack of confidence in the supply chain these days....
  6. JC91006
    16,936
    8,647
    You can buy complete KYB assemblies, that would be the best choice for DIY. I highly suggest you get a quality part so you don't have to waste your money and do it again after a couple years
  7. VFerdman
    1,200
    1,218
    So, do you have factual information about Monroe Quick Strut product (also a complete assembly, $100/side cheaper than KYB) that makes you think I will need to do it again after a couple of years? Per my records, it seems this car has been riding on Monroe Quick Struts since 2016 and 170K miles until now with 325K+ miles. That is a pretty good track record, if you ask me, but there may have been changes to the product that I am not aware of. This is why I am asking if people know a good reason NOT to use Monroe Quick Struts.
  8. JC91006
    16,936
    8,647
    it will all come down to the right quality that you can expect and tolerate. From my experience Monroe has not been very good and does not last very long. KYB used to be a very good brand now it’s not as good but still better than the Monroe brand. The best would be the OEM Toyota however they don’t sell complete units. Everything has to be purchased separately and it would be at a very high cost. If you’re satisfied with the Monroe ride that you have now I guess to save money you can buy Monroe again. everything comes down to you get what you pay for
  9. VFerdman
    1,200
    1,218
    I am also thinking this car does not have that much life left in it. It has a lot of rust in the usual wheel places and an original traction battery. It still works well and gets low 40's MPG, which is remarkable. It also has cost me very little over the years in terms of maintenance and repair. I really love this car, but I think it's coming to the end of life, unfortunately.
  10. JC91006
    16,936
    8,647
    So you’re basically buying time, maybe Monroe is a good choice in this situation
  11. Leadfoot J. McCoalroller
    8,289
    7,802
    Pennsylvania
    2018 Prius c
    If it were mine, I'd just get a better seat cushion and ride it out.
    Good luck whichever way you go!
  12. VFerdman
    1,200
    1,218
    Ha-ha-ha! I hear you. But I do think the shocks are shot. I will consider the cushion, though...
