Front struts
Discussion in 'Generation 1 Prius Discussion' started by Robin White, Aug 1, 2017.
  1. Robin White
    Robin White Junior Member
    2002 Prius
    I
    After 200K miles it's time (at least) to replace the front shocks and struts. I did a trial run to see how difficult it would be to gain access to the three mounting bolts on top, and found it no trouble at all. Now, most instructions will tell you to remove the wiper motor. It looks like I could gain access to the strut mounting bolts without this added step.
    Can anyone confirm it?
    Thanks,
    Robin White
  2. FireFighterHill
    221
    92
    Orlando/Clermont
    2003 Prius
    I
    I can confirm this. I recently did all the struts on mine. The rear struts are even easier. I recommend buying complete assemblies. Makes the take quick and easy.
    Robin White likes this.
  3. coolioe93
    coolioe93 Junior Member
    Houston
    I plan on doing this in a few weeks as well. I'll be buying this set from amazon
    2006-2009 Toyota Prius Quick Complete Struts Assembly / Shocks Absorbers (Set of 4)
    iPhone ?
  4. dabard051
    dabard051 Tinkerer-in-Charge
    250
    92
    Rochester, NY USA
    2002 Prius
    Yeah, removing the wiper motor makes things a bit easier, but it CAN be done without taking the wiper motor out. A ratcheting 12mm wrench is VERY helpful if you go that route.
    Robin, I think you may want to consider these:
    2002 TOYOTA PRIUS 1.5L L4 ELECTRIC/GAS Suspension Parts | RockAuto
    and click the (+) sign next to "Strut/Coil Spring/Mount Assembly"
    These are MUCH easier to install, pre-assembled, plus you get all new rubber pieces (that you would otherwise need to hunt around for)
    After 15 years, a can of Liquid Wrench spray may prove helpful.
    Plus a BIG 1/2 in breaker bar, and a torque wrench, for the larger nuts & bolts.
    #4 dabard051, Aug 20, 2017
    mroberds likes this.
  5. SDB54
    SDB54 Junior Member
    82
    32
    Northern CA
    Any suggestion for the fronts? I need to do mine.
  6. SDB54
    SDB54 Junior Member
    82
    32
    Northern CA
    Did you have to remove the back seats?
