Front suspension arm replacements
Discussion in 'Generation 1 Prius Discussion' started by Itsmeonprius, Aug 20, 2018.
  1. Itsmeonprius
    Itsmeonprius Member
    119
    56
    Scotland
    2001 Prius
    Active
    I'm struggling to find OEM replacement for the front suspension arms. Any suggestions, apart from stealer prices, where to get these from in the UK?
  2. vaughnstark777
    191
    33
    Roy, WA
    2001 Prius
    I
    You looking for the lower ball joint?
  3. vaughnstark777
    191
    33
    Roy, WA
    2001 Prius
    I
    Brian in Tucson likes this.
  4. ChapmanF
    18,959
    Looking for just the ball joints, or the actual LCA ?
  5. padroo
    padroo Senior Member
    2,763
    2,253
    Has anyone ever wore out a ball joint, I have never heard of that being a problem on Prius Chat?
    My experience with Prius front suspension is from my Gen 2 and I found them to be very basic and easy to work on.
  6. Itsmeonprius
    Itsmeonprius Member
    119
    56
    Scotland
    2001 Prius
    Active
    I'm really looking for the whole control arm from a UK supplier. I've spent most of this morning phoning around and getting crazy prices. Dealer is wanting £225 each and another can do it for £338 for both. This is nuts.
  7. Itsmeonprius
    Itsmeonprius Member
    119
    56
    Scotland
    2001 Prius
    Active
    If only I was in the US. That's a great price compared to what I've been finding in the UK.
  8. vaughnstark777
    191
    33
    Roy, WA
    2001 Prius
    I
    They ship to the UK.
    iPhone ?
  9. Itsmeonprius
    Itsmeonprius Member
    119
    56
    Scotland
    2001 Prius
    Active
    I see that and with import duty on top, it's worth exploring just buying the bushes. These look to be easier to get and I've got a press.
  10. Brian in Tucson
    Brian in Tucson Active Member
    981
    453
    Tucson AZ
    2003 Prius
    #10 Brian in Tucson, Aug 21, 2018
  11. Brian in Tucson
    981
    453
    Tucson AZ
    2003 Prius
    I don't know the mileage of his car, but he's putting a low mile replacement engine in, and I think he wants to renew the suspension and steering too. Can't blame him, even Prius parts do wear out. I would look into replacing the cv boots, do a thorough cleaning and a grease repack, too. Messy but cheap.
  12. Itsmeonprius
    Itsmeonprius Member
    119
    56
    Scotland
    2001 Prius
    Active
    Thanks Brian. I've been Google searching too and keep coming across this type of site but always out of stock.
  13. Itsmeonprius
    Itsmeonprius Member
    119
    56
    Scotland
    2001 Prius
    Active
    It's got 185k and now had a replacement 70k engine. The history paperwork shows a new driveshaft and a transaxle casing at some point so it's had a dunt side on. Chassis is straight and so is the subframe so it's been fixed good. All the fluids have been changed too. The ball joints are great. The only reason for changing the arm was that I saw that the rear bush was starting to split very slightly. But and this is where it gets annoying..... the bolts holding the arm were seized against the inner bush of the rubber bushes on all four. So the rubbers tore. Hence where I'm at at the moment.
  14. Brian in Tucson
    981
    453
    Tucson AZ
    2003 Prius
    Yeah out of stock, shame on them. You might call and ask them when they will get more, those parts aren't discontinued in the US. You might also try EU sources. Maybe in the Netherlands? Or Germany. They look like they fit on lots of cars at least. Sure isn't as easy as over here, tho.
    Or just get the bushings and press the old ones out and the new ones in.
  15. Brian in Tucson
    981
    453
    Tucson AZ
    2003 Prius
    Apparently Rockauto.com ships to the UK and doesn't try to rape you on the price.
    Here's the pertinent info. RockAuto.com Review by Garry in London, Uk, AE
    Rockauto is one of my favorite parts sources, and I've never had anything that went to back order!
  16. Itsmeonprius
    Itsmeonprius Member
    119
    56
    Scotland
    2001 Prius
    Active
    Thanks Brian. I've managed to grind and cut the old arms out. And AutoJapSpares.com can get me the correct size. I've also burnt and pushed the old bushes out in preparation.
  17. Brian in Tucson
    981
    453
    Tucson AZ
    2003 Prius
    Okay, well keep them in mind for future needs. You would fit right in around here!
    Itsmeonprius likes this.
  18. Itsmeonprius
    Itsmeonprius Member
    119
    56
    Scotland
    2001 Prius
    Active
    Update. New bushes finally arrived yesterday. Fitted like a glove tonight with new bolts all round. Nice to know I've got good bushes and nicely painted wishbones.
    Raytheeagle likes this.
