Front suspension replaced, now a clicking. Help troubleshoot?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Bunce, Jul 16, 2019.
  1. Bunce
    Bunce Active Member
    322
    185
    Oregon
    Hi.
    So I recently replaced my front suspension with the KYB spring shock all in one combo. All went well and pretty smooth. However I now have a clunk/click from the front right when turning tight, such as in and out of parking lot spaces and driveways. It wasn't there before. Everything was nice and tight when going back together.
    Any thoughts on what it could be?
  2. Patrick Wong
    18,200
    6,498
    Did you tighten the nut in the center of the top strut mount? The tightening torque is 35 ft.-lb.
    The tightening torque for:
    the three nuts that hold the top strut mount to the body is 29 ft.-lb.
    the two bolts at the bottom of the strut to the steering knuckle is 113 ft.-lb.
    the link to the antisway bar is 55 ft.-lb.
    Raytheeagle and SFO like this.
  3. M in KC
    M in KC Active Member
    358
    106
    KC, MO
    Clunk sounds are generally from improperly torqued fasteners as Patrick is suggesting above or another suspension part that has worn (e.g. sway bar bushing, sway bar connecting link, rack and pinion bushing or lower control arm bushing as examples).
    If your torque values are confirmed appropriate, elevate the front end of the vehicle to take the load off the suspension and start visually inspecting and physically checking the other suspension/steering components.
  4. Bunce
    Bunce Active Member
    322
    185
    Oregon
    I did not do the center nut as it's supposed to be pre assembled ready to go. I also didn't use a torque wrench since I don't have it with me (2600 miles away from home). Just tightened up using feel. I'll see if I can borrow a torque wrench and have another crack at it.
    The noise wasn't there before, so it must be something I touched or a very bad coincidence.
  5. Skibob
    Skibob Senior Member
    2,912
    1,502
    Northern California
    113 ft-lbs by feel? Some auto parts stores rent tools if you can’t borrow one.
  6. jb in NE
    jb in NE Senior Member
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    Less likely, but it could be a CV joint making the noise. I would first look at the struts you just installed.
  7. Bunce
    Bunce Active Member
    322
    185
    Oregon
    Just to update, I got less than a quarter turn more on the large, bottom shock bolts and no more clicking. So alignment done and drives much better now. Cheers.
    Skibob and jb in NE like this.
  8. andyg
    andyg Member
    50
    25
    Is it the same torque for 2008 Gen II Prius Struts? I am thinking of replacing my struts and rear shocks with OEM KYBs. My local Toyota dealer quoted $1600 for parts alone saying they don't just replace the struts but they change struts, mounts, et al. TIA
  9. Patrick Wong
    18,200
    6,498
    Yes, all 2G would be the same. You should also replace the top mounts and the rubber pleated boots that cover the top of the struts.
  10. andyg
    andyg Member
    50
    25
    Than you Patrick. I would also like to replace my Halogen headlight assembly as the original one are quite dim and unfocussed. Any recommendations on aftermarket brands or should I go for oems? Appreciate your advice
