Front suspension squeak
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by sciencekit, Jan 11, 2012.
  1. sciencekit
    sciencekit Junior Member
    76
    Norfolk, VA
    When I park, and let off the brake, the car will gently rock back and forth, emitting a squeaking sound as it does so from the front suspension area. I am replacing front and rear struts (195K miles on my Prius). Any idea what the squeaking could be? Thanks.
  2. northwichita
    481
    102
    29
    Wichita KS
    While replacing the stuts/shocks, also check the front sway bar links for the source of squeaks, happened to my high mileage prius.
  3. richard schumacher
    7,683
    1,066
    United States
    Set the parking brake first and I'll bet the squeak goes away :_> Lots cheaper than new shocks (but you probably need them anyway).
  4. sciencekit
    76
    Norfolk, VA
    Thanks. Checking the front sway bar links is a good idea. Oh, and yes, if I set the parking brake when I park there is no squeak. hehe I've done that a few times. :)
