Front turn signal and front hazard lights stopped working
Discussion in 'Gen 5 Prius Care, Maintenance and Troubleshooting' started by Jomo123, Apr 13, 2025.
  1. Jomo123
    Jomo123 Junior Member
    Upstate New York
    I changed the front bumper on my daughter's car and now the front turn signals and front hazard lights stopped working.
    Tonight I checked the passenger side and found out the following: The bulb is good and the wiring harness to the build has a ground but does not get 12v.
    Can I simply run a wire from the side signal (yes, it works) to the front signal light and be done? Of course, I will do this for both sides.
    Jomo
    #1 Jomo123, Apr 13, 2025
  2. frodoz737
    frodoz737 Top Wrench
    4,805
    2,561
    33
    No one likes an arm chair, but sounds like you left a connector off or loose. I would check again real good before "rewiring"...but that's me.
    #2 frodoz737, Apr 13, 2025
    Jomo123 likes this.
