Front USB outlet doesn't charge phone?
Discussion in 'Prime Technical Discussion' started by PiPLosAngeles, Apr 3, 2021.
  1. Old Bear
    Old Bear Senior Member
    712
    1,050
    Boston, Massachusetts USA
    I'm not sure that all of the various Prime trims and years have this feature, but I think Toyota addressed this problem by providing a "Qi" charging pad in the console:
    This is an elegant solution if your vehicle and your phone have Qi capabilities. Unfortunately, not all do.
  2. road2cycle
    road2cycle Active Member
    168
    109
    Sonoma County, CA
    I just connected to CarPlay this week and the USB port is able to charge my iPhone SE and run navigation through Google maps. I tested it out on my half hour commute home from work without any issues.
  3. dtsexpert
    dtsexpert Member
    179
    83
    San Francisco
    My Iphone Xs Max does get charge slowly while using the Carplay.
    Properly it needs a good cable in this case for data transfer & power out from the front usb same time.
  4. PiPLosAngeles
    PiPLosAngeles Senior Member
    1,551
    724
    The LE doesn't have it.
  5. amos
    amos Active Member
    371
    282
    los angeles
    Noticed that in my car too. Its not charging won't even show the arrow sign when connected .been like that since i got the car. usb charge On the gen 3 was charging well. I thought to open the connection panel cover there and check for loose wire? Did anybody do that?
